Posted April 9, 200619 yr so i kinda wanted to find out if there was a way that i could tell around how much my amp is putting to my subs cause i dont have a dmm (yet).....so is there a way that i could show the specs of my sub amp to you guys and tell you how my wiring is??Like i said i was just hoping to kinda get an idea of how much my subs are getting now.the wires are L+ and R- some im guessin is bridged but im not sure how my subs are wired yet(i didnt do it) but im pretty sure they are at 4ohms....D4 subs btwand here is the amp again.....http://www.lafayetteradio.com/amplifiers/RSA150.2HC.htm
April 9, 200619 yr http://www.concept-intl.net/download/measurwatts.pdfeasiest way to do this is explained here.
April 10, 200619 yr buy a cheap one----it is one of the most important things in car audio IMO----can get one for $15-$90 depends on how many measurements you want to be able to do.
April 10, 200619 yr Don't get the cheapest one though. I bought a Radio crap 10 dollar DMM and it can't read AC ratings so there goes my ability to do the gain settings.
April 10, 200619 yr I have one that wont go down to 10th's decimal placeSo when i read ohms i only get 1 number and no decimal
April 10, 200619 yr Find a friend or a friend of a friend that is an electrican, mechanic, etc. Anyone that plays with electricity will have one.
April 10, 200619 yr Author ok so i took the sub out and looked i hope this makes sense.....the sinlge piece of wire by itself goes from the right + to the left - ......then the wire that goes to the terminal goes from the right - to the left + .......i hope that makes sense it is right.... like i said i just wanted to see if you guys would kinda know around what each sub is getting....if not ill be able to get a dmm next week.
April 10, 200619 yr You are incredibly good at ignoring advice. Please listen to the answers when you ask a question. You NEED a DMM otherwise your gain settings could have you an order of magnitude off. Without measuring the voltage you CANNOT know what your subs are getting, it is not possible. If you are really concerned, you should have listened and just bought the Orion that was recommended. Buying the wrong gear is worse than paying too much for the right gear.
