Posted April 22, 201312 yr So I decided to make an amp rack. I figured I could make a simple wall cut-out with some simple cardboard templates and a skil saw. I spent the better part of the afternoon doing this. A Crescendo 3500 will go on this rack, I plan to make holes and grommets for all cables. I will put any distribution blocks or speaker terminal bays underside and or speaker connector block thing (Don't know the name). I'll update this as I finish it, and post it in a build log later. Just wanted to share what I did today! It's my first time, far from perfect or even clean looking. But this is a passion and a hobby of mine, and I want to do this all myself and learn from experience. I knew that planning and thinking about it would only go so far, time to apply. Well it's coming along, we'll see how it ends up. Here's what I've got so far: Inside of Trunk Another angle Another Angle Took some cardboard cutouts for the top sail and measured the height and length. Amp dimensions included for reference. Dimensions of Crescendo 3500 The main idea Cardboard cutout planning Some comfy room sounds good Looks good to me. Not looking for too close of a fit. A bit of a gap, but you won't notice a difference once it's carpeted I hope. Ignore the stock speaker. The ski access port is 8" by 8". This makes me curious about using it as a port. Any ideas behind that?
April 22, 201312 yr Author I think I might put a speaker connector plate on the rack for easy and clean speaker wire connections.
April 22, 201312 yr Author Thanks, I'll be adding a second rack on the opposite side for my front channel Arc Audio FD2100 amp next.
April 22, 201312 yr Thanks, I'll be adding a second rack on the opposite side for my front channel Arc Audio FD2100 amp next.Awesome! I hope to see it someday man.
April 22, 201312 yr Author Thanks, I'll be adding a second rack on the opposite side for my front channel Arc Audio FD2100 amp next.Awesome! I hope to see it someday man.XCON should be here about the same time the semester ends, in the 2nd week of May. We should definitely chill sometime man.
April 22, 201312 yr Yeah for sure! Hopefully my new setup is together by then. I have very high hopes for the new build.
April 22, 201312 yr Author Ok guys I have a question. What are some ideas on how to secure the Amp Rack? I'm thinking about making a trunk cutout from a sheet of birch as a floor. I'd then use right angle brackets and wood screws for the racks. I don't have a lot of tools.
April 24, 201312 yr Pics dont work for me, check out my playlist on youtube though, lots of stuff you may want to use.
April 24, 201312 yr Author Dang, links must've died when I put them into an album. Here are the pics.
April 24, 201312 yr Author I decided to make a better cardboard template and will have to make a second cut. Learning from my mistakes the hard way. Waiting on carpet from parts-express.
