April 30, 201313 yr Author and 20 Hz is low what is your box tuned to?running sealed. Sub prefers it over ported
April 30, 201313 yr I didnt know you could wire 3 D4's subs to 4 Ohms. Everywhere I've looked online show either 2.67 Ohms or 6 Ohmswhere did it say 3?It didn't I failed at reading.
April 30, 201313 yr I didnt know you could wire 3 D4's subs to 4 Ohms. Everywhere I've looked online show either 2.67 Ohms or 6 Ohmswhere did it say 3?It didn't I failed at reading.Its all good
April 30, 201313 yr If you're playing a song on tuning it's not going to cool..the coils don't move enough to cool anything @ tuning DD-1 works fine, if you use it right. Not setting your gains with -15....It doesn't work for setting gains, fucking stupid device.
April 30, 201313 yr Author Its funny how this site is gradually turning into the SSA forum peace out guys
April 30, 201313 yr Precision Power PPI BK1800.1DRMS Power Rating:4 ohms: 700 watts x 1 chan.2 ohms: 1100 watts x 1 chan.1 ohms: 1800 watts x 1 chan.
April 30, 201313 yr So you are giving them 500W combined? How did you get to the conclusion, what math did you use?How big is the box? is it the 4.2cu ft in your sig? (that's a little too much, but even that should make any problems with 500W)Did you double check your wiring? (did you measure it with a DMM to see if it actually is around 4 ohm?)It shouldn't be a gain problem, I don't understand why so many people think that is the problem. (if you set it correctly with the DD1 you should never have problems unless the amp will put out more power then it's rating.)The subwoofers should be able to handle 900W RMS, 1.8kW combined, in a sealed enclosure they should be able to handle 1kW, let alone 500W.I'm pretty sure you are hearing the sub bottoming out, not the dustcap if it's louder than the bass. (can you fit something between the dustcap and the cone? check this properly)
April 30, 201313 yr he's hooked up at 1 or 4, maybe he thinks if hes hooked up at 4 ohm and turns the gain all the way up hes getting 500 x2 =/
