  • Replies 525
  • Views 58.7k
  • Aaron Clinton
    Aaron Clinton
    Because our speakers are made to order in the USA, in one location with a pair of engineers that are some of the very best period, we keep our manufacturing with them.    The issue is, the constantly
  • well im not complaining about the price.. I just cant afford it like some of these others can but im a firm believer in that you get what you pay for... and casey sorry for takin over you build log wi
  • jcarter1885
    jcarter1885
    I wonder what SSA subs are really worth since the store pricing seems to be undercutting it? Just curious
I got some 8 guage ofc im pretty sure. might be 10. ill check when I get off work
Adding some 45s
post-21385-0-99875400-1403555030_thumb.j
post-21385-0-31903800-1403555080_thumb.j
Going to try some 10/4 wire for the subs. Got it pretty cheap cause it was leftovers
post-21385-0-61150300-1403555199_thumb.j
Edited by frogcase2002
I got that other wire if u need it and all those blocks. just lmk
Ill probably still need it for the ppi amps
im still on 6 12 hour days and 1 8. so you would probably have to come here but your more than welcome to it
Mite be able to come up there tomorrow. Ill bring an amp for you to try out on your Mids/highs
Pretty much just need to put the top of the enclosure on. . Going to sucked though cause my drill wont fit in the enclosure to do pocket holes and only have a little more than 5 inches on top so going to need to just use a screwdriver for most of the top screws.
Put the bit in a rachet. Will be little easier
I think ill try that :) Probably going to use a couple scissor car jacks in between the top of the enclosure and top of the trunk to "clamp" the top on then ill try using a rachet for the screws
Don't mind the sloppy cuts on the holes lol. Router broke a while ago so just been using my crappy jig saw I got.
post-21385-0-50714900-1403651555_thumb.j
The last part of the top will be removable just in case I need to do something inside the enclosure and don't feel like going through the sub or port holes. .
post-21385-0-73576500-1403651719_thumb.j
This is how I did the baffle. Got t-nuts in the middle of the 4 layers. And there nailed in real good through the other 2 layers so wont have a problem with the stripping like the spiked ones.
post-21385-0-65514400-1403652128_thumb.j
looking good!
looking good!
Thanks man
Awesome, I wanted to do a removable hatch on my box wasn't sure how to do it.
Man- Haven't looked in here in a bit....REALLY nice work!  Love the use of the 10/4 wire, and the sandwiched T-nuts.
Thanks! Just trying new things as I go. . Like every build I do lol
Anyone know of some good batts that are 5.5 inches or less on any of the dimensions? Would like to be able to fit some batteries on top of the enclosure back behind where I put my amps
The xs xp950 are a little over 5" wide.
They would work but I would need so many of them lol
Getting it bolted down :)
post-21385-0-87456800-1403804627_thumb.j
Ppi's fiting perfect
post-21385-0-43307400-1403804732_thumb.j
Cant wait to get this playing!! Lol
