I figured an amp that had visible fuses on it didn't needed to be fused additionally.
You must protect each part of a cable, the fuse on the amp is for protecting the amp itself.
With your setup it is possible to start an electrical fire: cable touches amp near wood, not enough current for the 250A fuse to blow, but enough to melt the small cable and generate a lot of heat. Not fun.
all of your batteries are Agm correct?
