Posted April 12, 200620 yr hey guys, i've been trying to think up all the slang/jargon that has to do with cars, let's see what all you can think ofso far, i've got:bump stick = cam shaftblower = superchargerhairdryer = turbocharger (or is it a supercharger? im not sure)slush box = transmissionskinnies = tiny front tiresjuice = hydraulics or nitrous, depending
April 12, 200620 yr Pickle fork = ball joint separatorRat powered = big block ChevThere's a lot.Even simple things like channelled (sp) ... or chopped ... or shaved.Layin' frame ... throwin' sparks ... tuckin' a wheel.
April 13, 200620 yr Dubs= 20'sDub Dueces= 22'sShoes are rims, not tiresDiegoed (sp?)= lowered in front and stock or lifted in the rear.Tuckin= sits above the fender lip.NOS= nitrious, even though NOS is a brand nameAnd everyones favourite;Pop trunk= remote trunk popper for bass drive buysOnly in TX though
April 13, 200620 yr 'Doggin=bull doggin=lower in the rearJacked = lifteddropped = loweredthingie ma bob = all things automotive (and is unaversally acceptible)slammed = uber low
April 13, 200620 yr mouse motor= SBCelephant= hemi, big hemimountain motor+ any huge displacement motorrockcrusher = fabled m22 four speedtoploader= earlier style ford manual trannytranny= transmissionspray= nitrousdraggin chrome = huge wheelstandcaged= roll cage inside carcager= car or truck, anything not a motorcyclericer= need i explain??that's all i can sit and think of..lol...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
April 13, 200620 yr Slush box is typically reserved for Auto trannies Acid.Pumpkin = rear (front on 4x4) differential.Slicks (self explanatory I think)Mouse = small block chevy.chop = lowered roofsectioned = body "chop" .... eg. doors and fenders have front to back piece removed then rewelded.channeled = lowering the body by modifying the floor pan usually.tubbed = cutting out and creating new bigger wheel wells to fit drag slicks.I'll think of more later I'm sure.
April 13, 200620 yr Body dropped= basically "sectioned" but its more new school<{POST_SNAPBACK}>I would call that channeled actually, sectioning is like mega hard to do.
April 13, 200620 yr Sleeper..ahh yesStealth= chrome delete, blacked out lights ect ect...everything black
April 13, 200620 yr Author Has anyone said "Road Head" yet?!Nope.I R teh pwn.Mike, remember the definition of head room?keep em coming guys
April 13, 200620 yr Has anyone said "Road Head" yet?!Nope.I R teh pwn.<{POST_SNAPBACK}>Mike, remember the definition of head room?keep em coming guys<{POST_SNAPBACK}> yes.. the definition of head room is not used for just audio....
April 13, 200620 yr Race from a "Roll" --The vehicles are already moving when you startRace from a "Dig" --Both vehicles are stopped when you start
April 13, 200620 yr Granny shifting.Speed shifting.double clutching (I know what it is but 90% of "car guys" get it wrong )Power shifting.In 4x4, "Granny gear" is often used.
April 13, 200620 yr Granny shifting.Speed shifting.double clutching (I know what it is but 90% of "car guys" get it wrong )Power shifting.In 4x4, "Granny gear" is often used.When you take the CDL test, you are supposed to double clutch, in reality, no one does. My understanding of double clutching is (never had to use it since I've never takin the CDL test, don't plan on it either, but I can still drive a semi...) Use the clutch to put the transmission in neutral, match the revs needed to downshift and use the clutch again to put into gear again. Used on unsychronized transmissions, you don't even need to do it if your know what your doing. Powershifting is when you shift a manual transmission w/o taking your foot outa the fuel. Granny shifting is shifting a tranny the normal slow wayNever heard of speed shiftingGranny gear = uber low gearing.
