Yes I tried hooking them up different ways but I couldn't get it to work right. I stopped before I fried something. I'll try again sometime. The shop couldn't understand the concept of only fronts and rms ratings so I'm on my own on this.
  • Replies 155
  • Views 17.3k
  • S.DeYoung
    S.DeYoung
    No need for tweeters in the rear, actually no need for ANY speakers in the rear.
  • altoncustomtech
    altoncustomtech
    "Surround sound effect" is NOT the point of DTA.  DTA is used to time the sound waves from each individual speaker to your ears so that the interaction of the sound waves happens as its intended in th
  • altoncustomtech
    altoncustomtech
    Time alignment is no gimmick but whether it's use is practical for your application I'm not entirely certain.  Time alignment is necessary when the speakers are different distances from your ears to g
Ill work on the RCA wiring, but is this the correct way to wire the speaker outputs together?
looks fine
Okay thanks
On that manual, i had a hard time understanding it. so both front and rear RIGHT channels on the deck are wired to both REAR channels on the amp and both front and rear LEFT channels on the deck are wired to both FRONT channels on the amplifier?
or should i split the front RCA outputs on the deck to do all four channels?
heres a link to a page to download the owners manual. http://www.alpine-usa.com/product/view/pdx-5/Specs
Edited by Trent Hari
  • 4 weeks later...
it seems as though your wiring to the speakers are correct though you need to use a y on the rcas for front left and right as well as rear left and right to condense the rear input to a single rca and the front signal to a single rca then connect 1 to the right channel front input on the headunit then the other to the left channel input on the head unit is how it reads
