Posted April 13, 200619 yr Now I am not going to point fingers at us amps quality because it is probably me doing something wrong. Anywho, I have a us amps xt1600.4 runnning focal polykevlar 5.25" components. I have the focals in stock door locations with the tweeters mounted on the pillars. The xt1600.4 has a .5 farad cap on it. I have not yet fine tuned the gains because i have not had the chance but they are roughly set. I expected this combo to blow me away, but it is not any better than the old boston component set I had running off the HU. My question is: Could the gains need to be changed, I mean, can that cause distortion? also, I have some sub par rca's from scosche. Could that be it? Lastly I have Some of the speaker wire and the rca run nest to a battery cable which i know is not good. If i move them apart, would the sound be better? I plan on doing that anyways, I just have a temp install right now until I can get my pops to help me build an amp rack and a better box. Any help s appreciated!!
April 13, 200619 yr you bridged the 1600.4 right? i mean if you do your gonna get a crapton of overhead on those comps so you should be powering them adequatelyalso set the gains using a DMM. i personally like setting by ear but to every person thier own.
April 13, 200619 yr Author you bridged the 1600.4 right? i mean if you do your gonna get a crapton of overhead on those comps so you should be powering them adequatelyalso set the gains using a DMM. i personally like setting by ear but to every person thier own.<{POST_SNAPBACK}>no. should i bridge it? that means the focals would see like 2oo watts a piece. Do you think they could handle it?
April 13, 200619 yr DO IT BRIDGED!! just set the gains accordingly. i had my rainbows rated at 60w with an md41 bridged (180w)remember set the gains accordingly.... you can never have too much overhead.what kind of distortion are you getting?
April 14, 200619 yr Dont forget to set the gains accordingly because setting the gains accordingly will make it so you can set the gains accordingly.Ohh yamake shure you set the gains accordingly
April 14, 200619 yr oh and remember.... set the gains accordingly i say that because people will blow thier speakers if they dont set thier gains accordingly
April 14, 200619 yr if you bridge it you can set the gains to recieve the exact power you want and give the comps the most they can possibly handle. that doesnt mean set THE gain to where they are jsut before clipping and expectthe comps to take it it means set them at the comps max which is probably higher then the unbridged output.
April 14, 200619 yr Author if you bridge it you can set the gains to recieve the exact power you want and give the comps the most they can possibly handle. that doesnt mean set THE gain to where they are jsut before clipping and expectthe comps to take it it means set them at the comps max which is probably higher then the unbridged output.<{POST_SNAPBACK}>ok i lost my manual....how do i bridge them?
April 14, 200619 yr you need 2 y-splitters... they are .99+ shipping at knu konceptz.then take the female ends of both splitters and hook them up to your original rca cables.... what you are doing is turning 4 channels into 2.for the speaker leads, bridge them like you would a 2 channel... what i do is treat a 4 channel amp like 2 2 channel amps... it always makes things clearer to me that way
