ok so i have 2 12" ssd (Ohm: Dual 1 Ohm, Dust Cap: Fire, FlatwindCoil: Yes+20, Cooling: Yes+30, QTS: H-Qts Sealed, Internal Lead: No) .. running off an R/F t1500 "brithsheet 1900w rms @ 1ohm" ... they both have VERY bad lead slap .. sounds like shit! .. so what do i do?
Something is wrong with your settings or enclosure. Go into more detail about those two things.
yeah i thought so ... thier in a temp box right now ... i'll wait and see what they do in the box i'm building
Enclosure..subsonic filter..
You should not be running them in a temporary enclosure that is not correct for them. You're going to end up breaking them if you are running into 'lead slap' because they are moving WAY too much.
