Posted May 31, 201313 yr Is there a name for this thing? Also has anyone found it at a local hardware store. it doesn't appear that home depot or lowes carry them. trying to avoid ordering it online but not sure i have a choice. thanks.
May 31, 201313 yr i got a basic dewalt dw618 from lowes.com and the jasper jig 200 off amazon. works amazing. im using a 1/2 inch bit and the jig is calibrated for a 1/4 bit so adjust your measurements accordingly. make sure you dont make your cut in 1 pass. take it little by little to extend the life of your router and bits. Edited May 31, 201313 yr by gt58
May 31, 201313 yr http://www.amazon.com/Jasper-200J-Circle-Cutting-Plunge/dp/B00009K77A/ref=sr_1_1?ie=UTF8&qid=1367605577&sr=8-1&keywords=jasper+jig+200 edit: make sure it will fit your router. http://www.jaspertools.com/routercompatibility.cfm Edited May 31, 201313 yr by gt58
May 31, 201313 yr Author Ok so looks like no choice but to order online. Alright.What do you mean by not in one pass? I've not used a router much at all. Do you mean take a little depth at a time?
May 31, 201313 yr Ok so looks like no choice but to order online. Alright.What do you mean by not in one pass? I've not used a router much at all. Do you mean take a little depth at a time? yes, after every pass i unlock it, twist it down some more, lock it and make another pass. should be some good tutorials on youtube
May 31, 201313 yr toolmaker jig is sweet.....jasper is ok, but they can be brittle. I went through 2 before I got this one
May 31, 201313 yr Homemade >>>> than the jasper pos. Good luck flush mouting with it.siq bro. i wish i could make cool things like you
May 31, 201313 yr As what Tim said, the Jasper jig is very fragile. I also went through two of them. I picked up one from Toolmaker for ~$80 and it's a beast. Made out of pure aluminum and able to make cutouts up to ~24" unlike what the Jasper jig can do. His version comes with practically all mounts so the router always stays flush on the material you are cutting. You never have to worry about the bolts loosening while using it to cut many circles or breaking the jig from it being too fragile.
June 1, 201313 yr Best jig. http://www.rockler.com/m/product.cfm?page=30473&mt=more_infoYou can get a circle/oval jig for about $90. Rockler is the only place I buy my woodworking tools.
June 1, 201313 yr Author Best jig. http://www.rockler.com/m/product.cfm?page=30473&mt=more_infoYou can get a circle/oval jig for about $90. Rockler is the only place I buy my woodworking tools.This one looks nice for the price. Might go with it thanks.
June 1, 201313 yr Homemade >>>> than the jasper pos. Good luck flush mouting with it. I'm not sure what the issue is, I haven't had any issues at all flush mounting with my Jasper jig. Aside from times I've used it for a couple of local guys I flushed in the rings for my components in the door baffles of my Jimmy and most recently the enclosure for the subs. I also don't understand breaking them. Accidents happen I suppose but fragile? The Toolmaker one sounds really nice though, I just don't understand why so many hate the Jasper. I've yet to have an issue with mine.
June 1, 201313 yr when i used to use jasper, if the bolts werent tight enough, cutting many holes would jar them loose and cause inaccurate cuts. tightening them tighter would spiderweb the jig because it's fragile.
June 1, 201313 yr I borrowed shizzons toolmaker jig and its nice.I think what sean is talking about for the flush mount is the sizing. You can only adjust in 1/16 increments and if the size you want is inbetween that you are out of luck. Or you have to make it oversize.I like the router buddy but you have to use a caliper to set the size. Works great but takes a little extra work.
