Bought some new toys to make the whole process easier!
New table saw, router, and Jasper tool for making perfect circles(Not shown)
  • Replies 86
  • Views 18.6k
  • Get a single set of components and use one of the sundown amps as a two channel bridging ch 1&2 and 3&4 to each side; or two raw 6.5s and two tweeters for an active setup.
  • Progress update. New enclosure and another SA-8.V2 + A new toy.
  • Update: UPS delivered me my other 6 subs that i ordered. I also picked up an XS battery, as well as made an amp rack in preperation for my other 3 amps i will be getting soon. Enjoy
Dont know if i calculated this correctly. Using multiple subs and a bigger enclosure is making everything hard to calculate. This is everything i plugged into the calculater. Trying to stick to around 20 sq inches per Cubic feet so in total i would have 160sq inches for 12 subs in a 9 cubic feet box.
Port is 28 tall, 6 inches wide, and 35 inches long for a 32 hz tuning. At least that is what the calculator tells me.
Any input? sound about right?
Sweet tablesaw, congtrats!!  I'd love to have a similar one.  What model #?  Also, what software are you using here?
Its a "Sawstop" Professional series.
The program was off of
http://www.decibelcar.com/apps/108-slotcalc.html
Very nice amp rack.  I always enjoy multiple smaller sub installs for some reason.
nice
Update: Got started on the base/Support and am in the process of sound proofing the underside to cut down on as much road noise as i can on a budget. Also got some more goodies in the mail. Still waiting on my American Bass 350.4 however :(
Update since last post: Filled in all the spaces and gaps with poly-fill and foam matting, sealed with aluminum tape, finished the support/false floor, started the enclosure, and built an enclosure for my mids and highs. Also got my american bass 350.4 amp which is going to need a hospital visit(in pics).
  • 3 weeks later...
Went to a show this past weekend. heres some pics i took.
Back to the updates on the build:
Bought a tablet to use as an in-dash audio control but ended up changing my mind and going with a 1st Gen Ipad
More Goodies
Port done and coated with resin
Test fit
Router jig really helped out alot with the holes
3 inch thick baffle
