Posted June 21, 201312 yr i know this sounds like a newbie question but i wanted to get the right answer. okay, so i have a rf t1000-1bd. it says that the amp is wired in parallel inside the amp. does this mean i can put a wire from each terminal on my woofer to each one of the 4 outputs and it will automatically take my dual 2 down to a 1 ohm load internally?. basically i wanna bump up the wire size going to my woofer because im used to the jumper and twist technique, but if i can get a fatter 10 gauge wire i'd like to do that. so basically instead of me doing the parallel wiring and only 2 wires coming from my sub, i'll have 2 wires from each voice coil, 4 wires going to my amp and the amp will put out power at 1 ohm? can anyone confirm that this technique will work and i will get the 1 ohm load?
