Posted July 17, 201312 yr ok i heard many things about these amps. especially them being very sensitive about power voltage / signal input voltage? any specific details about these amps one must kno before using them? what is the maximum signal voltage on these amp specifically the 2k5e 1ohm ? i plan on buyin 10 8ohm speakers for this amp
July 17, 201312 yr dont run them below 1ohm if you have the 1ohm versiondont run them below 2 ohms if you have the 2ohm version run dual 1/0inputs not sure about signal voltage my pioneer is 4v, have fun Edited July 17, 201312 yr by djjdnap
July 17, 201312 yr Author dont run them below 1ohm if you have the 1ohm versiondont run them below 2 ohms if you have the 2ohm version run dual 1/0inputs not sure about signal voltage my pioneer is 4v, have fun thanks and i will be using it for my vocals .. up here where im from i gotta keep up with the extreme midrange setup most ppl have .... i jus thought its more convenient to run 1 amp for those correction ( 8 ) , 8ohm speakers than 2 or even 4 amps !!!
July 17, 201312 yr dont run them below 1ohm if you have the 1ohm versiondont run them below 2 ohms if you have the 2ohm version run dual 1/0inputs not sure about signal voltage my pioneer is 4v, have fun thanks and i will be using it for my vocals .. up here where im from i gotta keep up with the extreme midrange setup most ppl have .... i jus thought its more convenient to run 1 amp for those correction ( 8 ) , 8ohm speakers than 2 or even 4 amps !!! You're okay with mono?
July 17, 201312 yr Author dont run them below 1ohm if you have the 1ohm versiondont run them below 2 ohms if you have the 2ohm version run dual 1/0inputs not sure about signal voltage my pioneer is 4v, have fun thanks and i will be using it for my vocals .. up here where im from i gotta keep up with the extreme midrange setup most ppl have .... i jus thought its more convenient to run 1 amp for those correction ( 8 ) , 8ohm speakers than 2 or even 4 amps !!! You're okay with mono?yea definitely as long as the sound is clean.. i got an o-scope so ill be tuning the gains with it
July 17, 201312 yr dont run them below 1ohm if you have the 1ohm versiondont run them below 2 ohms if you have the 2ohm version run dual 1/0inputs not sure about signal voltage my pioneer is 4v, have fun thanks and i will be using it for my vocals .. up here where im from i gotta keep up with the extreme midrange setup most ppl have .... i jus thought its more convenient to run 1 amp for those correction ( 8 ) , 8ohm speakers than 2 or even 4 amps !!! You're okay with mono?yea definitely as long as the sound is clean.. i got an o-scope so ill be tuning the gains with it You don't want right and left separation?
July 17, 201312 yr Author Yeah, that would sound like crapactually i heard lots of mono setups and it sounds good in my room i got 4 8" all in one channel on a macro tech and it sounds clean
