recommendations needed for an amp the plan currently is to run incriminator audio comps up front and a dcon 15 dual 4 in a ported box in the back now Id prefer to only have to run one amp and to slightly over power the dcon so what 4 channel amps do you think would be worth it to bridge the rear channels or are there any great 3 channels or even 5 channels since I could hook the rear channel on a 5 channel to my drop down tailgate speakers
Thanks guys
Well, because you would need to wire your Dcon to 2ohm bridged on a 4chan amp, you would need a 4chan amp stable at 1ohm per channel..
I do not even know if they make them like that so i'll go ahead and tell you that a 5channel amp is recommended.
Massive Audio NX5-
http://www.sonicelectronix.com/item_27733_Massive-Audio-NX5.html
120x4 @4ohm and the mono channel is rated for 800w @1ohm.
So, you should expect 400-500w @2ohm.
thank you for that it seems to fit the bill perfectly though is it good quality and I would still like a few other ideas thank you
I wouldn't post something i wouldn't run.
cool much appreciated yall are very helpful here im just attempting to finalize my design since my financial aid should be in soon im sick of having stock
I had an Audiobahn A4125HCT that would do it without a problem. Probably the ugliest amplifier in existence but it did it.
Are they still around or under new ownership?
No they went to shit fast. I just have a couple of their old amps.
