Posted July 28, 201313 yr recommendations needed for an amp the plan currently is to run incriminator audio comps up front and a dcon 15 dual 4 in a ported box in the back now Id prefer to only have to run one amp and to slightly over power the dcon so what 4 channel amps do you think would be worth it to bridge the rear channels or are there any great 3 channels or even 5 channels since I could hook the rear channel on a 5 channel to my drop down tailgate speakersThanks guys
July 28, 201313 yr Well, because you would need to wire your Dcon to 2ohm bridged on a 4chan amp, you would need a 4chan amp stable at 1ohm per channel.. I do not even know if they make them like that so i'll go ahead and tell you that a 5channel amp is recommended. Massive Audio NX5-http://www.sonicelectronix.com/item_27733_Massive-Audio-NX5.html 120x4 @4ohm and the mono channel is rated for 800w @1ohm.So, you should expect 400-500w @2ohm.
July 28, 201313 yr Author thank you for that it seems to fit the bill perfectly though is it good quality and I would still like a few other ideas thank you
July 28, 201313 yr Author cool much appreciated yall are very helpful here im just attempting to finalize my design since my financial aid should be in soon im sick of having stock
July 31, 201312 yr I had an Audiobahn A4125HCT that would do it without a problem. Probably the ugliest amplifier in existence but it did it.
July 31, 201312 yr I had an Audiobahn A4125HCT that would do it without a problem. Probably the ugliest amplifier in existence but it did it.Are they still around or under new ownership?
August 1, 201312 yr I had an Audiobahn A4125HCT that would do it without a problem. Probably the ugliest amplifier in existence but it did it.Are they still around or under new ownership?No they went to shit fast. I just have a couple of their old amps.
