July 29, 201312 yr Author 4 sundown sa8 v2 d4 at 35hz 2 cu/ft box. Id Rather not run at .5 ohm daily, if I do ill be using a crescendo bc2000, exploring options. Budget up to 600ish
July 29, 201312 yr 4 sundown sa8 v2 d4 at 35hz 2 cu/ft box. Id Rather not run at .5 ohm daily, if I do ill be using a crescendo bc2000, exploring options. Budget up to 600ishWith dual fours you can't do .5 ohms. Run a class D mono at 2k or 2.5k @1 ohm. Sorry I am wrong but 2k @ 2 ohms is cheaper Edited July 29, 201312 yr by pmureika
July 30, 201312 yr 4 sundown sa8 v2 d4 at 35hz 2 cu/ft box. Id Rather not run at .5 ohm daily, if I do ill be using a crescendo bc2000, exploring options. Budget up to 600ishWith dual fours you can't do .5 ohms. Run a class D mono at 2k or 2.5k @1 ohm.Sorry I am wrong but 2k @ 2 ohms is cheaperWith duel 4's he can run at .5 ohms. 4ohm+4ohm=2ohm x4. 2ohm+2ohm=1ohm.x2 then 1ohm+1ohm=.5ohm. So yes with 4 duel4 subs you can wire at .5ohms.
July 30, 201312 yr Get 2 amps (1000 w @ 1 Ohms each) and link them both.You will have those 2000 w rms @ 2 Ohms for your 4 D4 subs.
July 30, 201312 yr 4 sundown sa8 v2 d4 at 35hz 2 cu/ft box. Id Rather not run at .5 ohm daily, if I do ill be using a crescendo bc2000, exploring options. Budget up to 600ishWith dual fours you can't do .5 ohms. Run a class D mono at 2k or 2.5k @1 ohm.Sorry I am wrong but 2k @ 2 ohms is cheaperWith duel 4's he can run at .5 ohms. 4ohm+4ohm=2ohm x4. 2ohm+2ohm=1ohm.x2 then 1ohm+1ohm=.5ohm. So yes with 4 duel4 subs you can wire at .5ohms.Yes you can I was wrong, but running at .5 ohms if its a daily driver isn't good. Are you going to run two subs off each channel? Edited July 30, 201312 yr by pmureika
July 30, 201312 yr I would not run .5 daily unless your electrical is great. run 2k at 2ohms off of 1 amp
