would anyone know how much more on average you can increase the output of a stock alternator just by doing a rewind. i added a second battery which is not much. the second battery is my old battery that is a stock from upfront in the engine bay. i have the 130amp alternator from a 2003 highlander, just need to get to 200A output but i know each alternator is different and will not be able to get much more out of it. thanks to all that can help me
im kinda on a really tight budget saving money on a house as well so have to balance spending and saving
edit:
is there a difference between rewind and rebuild
Edited by grumby13
edit:
Yes there is.
They don't rewind rebuilds.
On a rebuild you usually can only get the same amp as oem.
dayum i just want to boost the output as much as i can but still be able to have it for a couple years
i was asking about the diffference between the two
Edited by grumby13
Is this an AGM Battery or an acid battery?
the one upfront is a agm a duralast platinum 34r and the one in the back or second one is an acid battery which is the old one i had upfront
I would definately switch that around and put the AGM in back and the acid upfront. Its not safe to have a lead acid battery inside the vehicle.
This x2.
Perhaps another batterie/s if money is tight. Used.
i just added another battery and my vdrop is still high when i crank it up. i just installed the battery yesturday and so far the vdrop at normal volume and when i compete is about half to 75% of the vdrop. im assumption now is my alternator i have a bc200d wired to 1 ohm but have not calculated box rise yet since im missing some tools to do so. and with the stock alternator from a 03 highlander im left with 95 amps to play with but the amp at full tilt is 144amps draw.
@DanP right now that is my only option since i do not want to put the old battery back since i have no idea how much longer it has. the battery is about 5 to 7 years old
I wouldn't use a battery that old. Get another agm thats new so you start with fresh batteries.
The atm underthe hood keeps bulging and idk why but I have a hunch of either heat or voltage drop
