Posted September 8, 201312 yr What could describe the noise of clipping/clicking when my sub hits a low note?
September 8, 201312 yr Author 26hz does it the most. I usually listen to mostly decaf music but these songs with the lower frequencies does this annoying sound most. A friend and I thought it was air leaks but fixed that and it's not as bad as it was. I just need some other input on what might be causing this sound. The sub is an sa15 on an American bass ph4000md. The box is 4.1cubes tuned to 32hz
September 10, 201312 yr sounds like it's bottoming out especially the size box you have that sub in. Play at lower volumes and see if it's present in the front stage speakers first.Sometimes modded music has transient clipped peaks that "pop" when not edited correctly. You rule that out, then i'm aiming at bottoming out.
September 11, 201312 yr 26hz does it the most. I usually listen to mostly decaf music but these songs with the lower frequencies does this annoying sound most. A friend and I thought it was air leaks but fixed that and it's not as bad as it was. I just need some other input on what might be causing this sound.The sub is an sa15 on an American bass ph4000md. The box is 4.1cubes tuned to 32hzI lol'd at the 32Hz box, weird sound at 26. Hmmmm. Lol
September 15, 201312 yr Author sounds like it's bottoming out especially the size box you have that sub in. Play at lower volumes and see if it's present in the front stage speakers first.Sometimes modded music has transient clipped peaks that "pop" when not edited correctly. You rule that out, then i'm aiming at bottoming out.thank you 26hz does it the most. I usually listen to mostly decaf music but these songs with the lower frequencies does this annoying sound most. A friend and I thought it was air leaks but fixed that and it's not as bad as it was. I just need some other input on what might be causing this sound.The sub is an sa15 on an American bass ph4000md. The box is 4.1cubes tuned to 32hzI lol'd at the 32Hz box, weird sound at 26. Hmmmm. Lolyea i know. at 20 hz the noise is not there at all, and it sounds good and clean..
September 15, 201312 yr There is a song or two of decafs that hits 26hz and they sound weird on my system. Other songs that i have that go that low do not sound strange at all. I think its just that song and whatever decaf did to it.
September 15, 201312 yr Author There is a song or two of decafs that hits 26hz and they sound weird on my system. Other songs that i have that go that low do not sound strange at all. I think its just that song and whatever decaf did to it.i was thinking that just now, and that makes since, thank you
September 15, 201312 yr There is a song or two of decafs that hits 26hz and they sound weird on my system. Other songs that i have that go that low do not sound strange at all. I think its just that song and whatever decaf did to it.i was thinking that just now, and that makes since, thank youNo problem. Search around and see if you can find a song that has the same frequency and play it and see if you still get a weird noise.
