So I want to do a new build with ssa subs. Current set up is a skar 1500 and a havoc 15 in 3.5 @ 33 hz. It don't not have to be louder than this just looking for some thing different. I have about 8 cubes of space. I'm border line for stock electrical but do have a xs2400 on the way. Goals are daily but I would like a pretty flat response like killing the lows. Maybe 2 15 dcons amp turned down of course or a xcon 18.
  • Replies 70
  • Views 5.8k
  • Frostedflakejake
    Frostedflakejake
    Yes you do. But you're assuming way too much.  Your speaker is not a perfect 1 ohm device Your amplifier has some sort of impact on that resistance Your amplifier is most definitely not 100% efficient
  • Quentin Jarrell
    Quentin Jarrell
    And tens of millions of others have yet to loose a sub.  The just spent about $200 less doing so.
  • Quentin Jarrell
    Quentin Jarrell
    A DMM at home depot is $10 bucks.  Just as useful, actually more useful.
currently have a AA havoc? box sounds a bit small.
new box will improve low end response. no need to spend more cash
Edited by lithium
I just get the itch for something new havoc box spec are in range but yea on smaller side.
model the sub in the enclosure you have now VS a larger enclosure. guaranteed it will have more low end!
at the very least, spend the 40 bucks to build a new box and test it out!
I think its like 8.60 total my use areos for less port displacement. May even try a sealed setup. Got me thinking about a new box build.
Not sure I'm getting full power out of my amp. I have a 80 amp fuse inline yet to blew it. Watts equalls amp x volts right.
A sk-1500?
That amp will do more then rated power @ 14.4 volts.
A sk-1500?
doesn't matter if it does, you wouldn't able to hear a difference
14.4 volts x 80 amps = 1152 watt and I have a highs amp. I can't pop the fuse. Sub is dual 2 wired to 1 ohm.
doesn't matter. 1000 vs 1500 watts isn't audible
How did you determine you were higher than 1152 amps. What was your other sub rated for?
What no you need to do over 1152 watts to pop a 80 amp fuse.
He said he thought it wouldn't be pulling a full 1500w because the inline 80 amp fuse would have blown at 1152W.
But how high were your gain settings.Plus how did you determine you were at full power?
I used dd-1 on track 5 to set gains 0 gauge run to amp. Let me know if I'm wrong I want learn. That's why I wanted to try dcons because of there sensitivity. Get loud on less power
AWWWWW YYEEEEAAAA ON THAT DD-1!
Good tool or no. Not sure
I am sorry to hear you spent your money on a useless meter. To set gain you should use your ears and nose to adjust it.
  • Popular Post
  • Your speaker is not a perfect 1 ohm device
  • Your amplifier has some sort of impact on that resistance
  • Your amplifier is most definitely not 100% efficient.
And all this is besides the point. As others point out your settings on your amplifier and the signal it is receiving is what determines your output. It also takes power to make power. It's possible that your electrical system isn't up to the task to provide a proper amount of current for your amplifier to make it's rated/claimed power.
To your original post, I ran two 15" dcons and absolutely adored them. Ported with aeroports like you were suggesting tuned to about 33hz. They are delectable woofers
+1 For Frosted Flake Jake.
Dcon are back ordered right. Wish I could run three. I would like to just step back a bit on my stock eletric. Then just make it back up with cone area and sensitivity.
I think the dd-1 is a good tool for setting gains. Me and my friends yet to lose a sub. Knock on wood
I've never used one and I've never damaged a woofer. I haven't been around for too long, but still.
You absolutely do not need one. But you already got one so there is no reason to continue down that path.
I guess if you're trying to decide what subwoofers to run I would look at goals, budget, and space allocation. You vaguely answered goals and referred to your space capacity so that just leaves budget.
