Posted October 24, 201313 yr Just ordered a BL12 Fully Loaded and was wondering if a SQ Q-1-2200D would be a good fit with it. I currently have a RE Audio CTX 3200.1 but I do not think it will have enough to push it's potential car already has big 3 upgrade and 200 amp alt and 2 runs 0/1 to the trunk
October 25, 201313 yr Author I probably will was just wondering if anyone else was running a similar setup.
October 27, 201313 yr try it out first. I'm not familiar with RE's new amps, but I'm guessing that puts out like 1500 rms supposedly?
October 27, 201313 yr Author puts out 1200 supposedly they are not the caliber that US amps once were their newer USX series are more like what they used to produce.
October 27, 201313 yr Unless you are chasing barely audible changes I wouldn't bother. I'd rather upgrade to a better quality amp of the same power than to upgrade for the sake of "potential"
October 28, 201313 yr Author Unless you are chasing barely audible changes I wouldn't bother. I'd rather upgrade to a better quality amp of the same power than to upgrade for the sake of "potential"very true
October 28, 201313 yr You're looking at close to double the power....and power compression, thermal and mechanical limits alobg with two dubious amplifier brands. Not where I'd recommend spending money first
October 28, 201313 yr Author You're looking at close to double the power....and power compression, thermal and mechanical limits alobg with two dubious amplifier brands. Not where I'd recommend spending money firstI appricate all the advice and I am going to do more research into it before making any decisions and look into better amplifiers.
