Posted May 3, 200620 yr Is the BM supposed to be better than the Mag, or is it the other way around? I just got a new SUV, so need some bumps!
May 3, 200620 yr ^ What he said. The BM's are a level below a Mag. I almost said "entry level" but they are by no means an entry level woofer with a double stacked motor, 2.5" coil, and the ability to sound similar to a Mag and still have great output. The BM's just won't handle the 1k+ each that the Mag's will.
May 4, 200620 yr Author ^ What he said. The BM's are a level below a Mag. I almost said "entry level" but they are by no means an entry level woofer with a double stacked motor, 2.5" coil, and the ability to sound similar to a Mag and still have great output. The BM's just won't handle the 1k+ each that the Mag's will.<{POST_SNAPBACK}>Thanks for both of your quick responces.
May 4, 200620 yr Admin the BM is more of a mid level sub, well by looking at the specs and posts about them
May 11, 200620 yr <little kid mode>Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???Do you have them yet???
