I preordered the diyma 12" but need something to run in the meantime. the amp i have is 500w rms, probably underrated. i'm looking at either one of the eclipse sw 8000 lmt 10's sealed or a single rli-8 ported. The treo ssi 8" is on the list as well and it would be ported.
  • Replies 59
  • Views 6.3k
drop the ssi...treo's customer service sucks.
damn...the eclipse would be kewl....
as would the rl-i...
crap..i dunno.....
i vote for the eclipse, but ported. and i get dibs on it when you sell it.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
lol, playing with the numbers on the lmt eclipse's they take huge boxes and i don't have my car anymore, back in a regular cab Ram.
Try out the eclipse, be the guinea pig ;)...
I'd like to hear some real world input... someone who gets to use them ;)....
nG
Joe can you go with a single LMT 10?
shit..we can get a pair of 15's sealed behind the seats of the new rams..so the lmt 10 shouldn't ba an issue...lol..
and i've done ported 12's in the older ones...
get the 10, let us know..and then sell it to me when your real sub gets there!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
no lie, depending on the year yo ucan get 2-3ducft sealed ;)
and that is with full seat functionality
what size box does the Eclipse 8200 12 need?
no idea, and you know eclipse tech support is like pulling teeth. my local dealers act like they've never heard if these too.
actually that was easy. eclipse tech support says "NO ported".
sw 8000 10" .3-1.0ft net
sw 8200 12" .5-1.5ft net
Edited by JoeHemi57
they said that about the older alumns,
but those specs are not bad I was expecting closer to 3 for the 12
there were ported boxes on the spec sheet of my sw8102 i think but yeah when you called they recommended sealed. i really want to grab that 10" but i need to get my head unit and wires first or it would just sit around anyway.
No ported...lol
Yet the LMT from TC you can port just fine :blink:
I am curious the differences between the 8200, RL-s, TC 4Hp
hopefully the eclipse subs will be a little more automotive friendly than the Rl-s.
with smaller box requirements they should be,
but I wonder if the 8200 has H2 syndrome, where the company posts small box requirements and when in reality the sub needs a much larger box
if they recommend sealed and u still want to try ported..do a 4th order bandpass
they should do well in that kind of a box
80
i plan to try the 10 in the same box i'm gonna use for my diyma 12", just gonna cut the hole bigger once it comes in. i'm planning on about .9 gross airspace.
I forget, how many watts is it getting?
That Treo amp i posted is gonna be the power and its an underrated 500w bridged @4ohm. i'm trying to sell my diyma preorder spot so i can go ahead and order the sub.
I knew that was the amp, just did nto know the model or the wattage. By the looks of the internals it will be alot more than 500.
i think it will push a solid 600-650w so you guys think i should go for the 12 if i can get the preorder spot sold?
Am I misreading you? bail on the DIY and go with the 8200?
if so I like that idea
