HD Line- (High Definition)
The HD line is a line of Mono amplifiers with Full Range Class D frequency response up to 15KHz with amplifiers currently rated from 1200 to 8000 Watts of power @12.6v. Product of high yield, innovative design and edges (Front and Back) on ABS, which provides greater security at the time of their installation, these products have RCA type inputs, (L and R), to seize the entire mix of a song directing to a single output.
This line uses SMD technology resulting in less heat buildup(less heat dissipation required), smaller heatsinks, smaller footprint, less internal parts required, higher efficiency(mid to high 70% @ low ohm stability level).
Below, you will see the following-
Maximum Consumption Musical
Maximum Consumption in Sinusoidal Signal
This is what it means-
Maximum Musical Consumption- Max current the amp will draw when a speaker(s) is wired to it's lowest stable ohm load and "rise" to a given figure.
Maximum Sine Wave Consumption- Max current the amp will draw on a FIXED Resistance.  This is the current draw typically given by other buildhouses.
All of the following amplifiers listed under the HD Line come in 1ohm AND 2ohm models!
The following listed specs are of the 1ohm version.  The 2ohm versions share the exact same output power except at twice the impedance.
The HD1600 comes in 1, 2 and 4 low ohm stability models.  Efficiency levels of higher ohm load amps vary but typically are about 2% more efficient.
HD1200-
Number of Channels: 1
Maximum Power @ 13.8 VDC - 1 OHM: 1439W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 813W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 446W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 1200W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 678W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 372W RMS
Input Sensitivity: 250mV @ (-9,78 dBm)
Total Harmonic Distortion (THD): 0.3%
Frequency Response: 10Hz to 15KHz
Crossover:
H. P. F (High Pass Filter): 10Hz to 50Hz(-12dB/ 8nd ) Variable
L. P. F (Low Pass Filter): 50Hz to 15KHz(-12dB/ 8nd ) Variable
Bass Boost: 0 to 10 dB (50Hz)
input Impedance: 18K OHMS
Protection: Short on the Output / Voltage of High / Low Power
Supply Voltage: 10.5VDC Minimum
Supply Voltage: 16VDC Maximum
Consumption at Rest: 1.20 Amp.
Maximum Consumption Musical @ 12.6VDC: 57 Amp.
Maximum Consumption in Sinusoidal Signal (1Khz) @ 12.6VDC: 114 Amp.
Dimensions (WxHxD): 9.02" x 2.56" x 8.08"
Weight: 4.37lbs
HD1600-
Maximum Power @ 13.8 VDC - 1 OHM: 1919W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 1304W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 805W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 1600W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 1088W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 672W RMS
Crossover:
Maximum Consumption Musical @ 12.6VDC: 99 Amp.
Maximum Consumption in Sinusoidal Signal (1Khz) @ 12.6VDC: 198 Amp.
Dimensions (WxHxD): 9.02" x 2.56" x 9.53"
Weight: 5.52lbs
HD2500-
Maximum Power @ 13.8 VDC - 1 OHM: 2998W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 2159W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 1319W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 2500W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 1800W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 1100W RMS
Crossover:
Consumption at Rest: 1.40 Amp.
Maximum Consumption Musical @ 12.6VDC: 135 Amp.
Maximum Consumption in Sinusoidal Signal (1Khz) @ 12.6VDC: 270 Amp.
Weight: 5.73lbs
HD3000-
Number of Channels - 1
Maximum Power @ 13.8 VDC - 1 OHM: 3598W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 2446W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 1403W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 3000W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 2040W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 1170W RMS
Input Sensitivity: 250mV @ -9,78 dBm
Total Harmonic Distortion (THD) 0.3%
Signal / Noise Ratio: >95dB
Damping Factor: 300
Frequency Response (Full Range): 5Hz to 15KHz
Crossover:
H. P. F (High Pass Filter): 5Hz to 50Hz (-12dB / 8nd ) Variable
L. P. F (Low Pass Filter): 50Hz to 15KHz (-12dB / 8nd ) Variable
Bass Boost: 0 The 10dB (50Hz)
Input Impedance: 18K OHMS
Protection: Short in Supply Voltage Output / High / Low
Minimum Supply Voltage: 10.5 VDC
Supply Voltage: 16 VDC Maximum
Consumption at Rest: 1.70 Amp.
Maximum Consumption Musical @ 12.6VDC: 170 Amp.
Maximum Consumption in Sinusoidal Signal @ 12.6 VDC: 340 Amp.
Dimensions (WxHxD): 9.02" x 2.56" x 11.34"
Weight: 6.86lbs
HD4000-
Maximum Power @ 13.8 VDC - 1 OHM: 4798W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 3171W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 1876W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 4000W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 2644W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 1564W RMS
Crossover:
H. P. F (High-Pass Filter): 10Hz to 50Hz(-12dB/ 8nd ) Variable
Bass Boost: 0 to 10dB (50Hz)
Protection: Short circuit in output / Voltage of High power/Low
Minimum Supply Voltage: 10.5VDC
Consumption at Rest: 2 Amp.
Maximum Consumption Musical @ 12.6VDC: 202.5 Amp.
Maximum Consumption in Sinusoidal Signal (1Khz) @ 12.6VDC: 405 Amp.
Dimensions (WxHxD): 9.02" x 2.56" x 14.76"
Weight: 9.08lbs
HD5000-
Number of channels - 1
Maximum Power @ 13.8 VDC - 1 OHM - 5997W RMS
Maximum Power @ 13.8 VDC - 2 OHM - 4000W RMS
Maximum Power @ 13.8 VDC - 4 OHM - 2398W RMS
Maximum Power @ 12.6 VDC - 1 OHM - 5000W RMS
Maximum Power @ 12.6 VDC - 2 OHM - 3335W RMS
Maximum Power @ 12.6 VDC - 4 OHM - 2000W RMS
Damping Factor: 400
Frequency Response: 5Hz to 15KHz
Crossover:
H. P. F (High Pass Filter): 5Hz to 50Hz (-12dB/ 8nd ) Variable
L. P. F (Low Pass Filter): 50Hz to 15KHz (-12dB/ 8nd ) Variable
Consumption at Rest: 2.0 Amp.
Maximum Consumption Musical @ 12.6VDC: 295 Amp.
Maximum Consumption in Sinusoidal Signal (1KHz) @ 12.6VDC: 590 Amp.
Dimensions (WxHxD): 9.02" x 2.56" x 17.6"
Weight: 11.44lbs
HD6500-
Maximum Power @ 13.8 VDC - 1 OHM: 7796W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 5129W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 3079W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 6500W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 4277W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 2567W RMS
Signal-to-Noise Ratio: >95dB
Damping Factor: 400
CROSSOVER:
H. P. F (HIGH PASS FILTER): 5Hz to 50Hz(-12dB/ 8nd ) Variable
L. P. F (LOW PASS FILTER): 50Hz to 15KHz(-12dB/ 8nd ) Variable
System of Protection: Short on the Output Voltage / High power/Low
Consumption at Rest: 2.50 Amp.
Maximum Consumption Musical @ 12.6VDC: 351 Amp.
Maximum Consumption in Sinusoidal Signal (1Khz) @ 12.6VDC: 702 Amp.
Dimensions (WxHxD): 9.02" x 2.56" x 18.82"
Weight: 11.46lbs
HD8000-
Maximum Power @ 13.8 VDC - 1 OHM: 9595W RMS
Maximum Power @ 13.8 VDC - 2 OHM: 6305W RMS
Maximum Power @ 13.8 VDC - 4 OHM: 3646W RMS
Maximum Power @ 12.6 VDC - 1 OHM: 8000W RMS
Maximum Power @ 12.6 VDC - 2 OHM: 5256W RMS
Maximum Power @ 12.6 VDC - 4 OHM: 3040W RMS
Total Harmonic Distortion (THD): 0.5%
Signal / Noise Ratio: >90dB
Damping Factor: 400
Frequency Response: 5Hz to 15kHz
Crossover:
H. P. F (High Pass Filter): 5Hz to 50Hz(-12db/ 8nd ) Variable
L. P. F (Low Pass Filter): 50Hz to 15kHz(-12db/ 8nd ) Variable
Input Impedance: 18k OHMS
Protection: Short on the Output / Supply Voltage High/Low
Maximum Consumption Musical @ 12.6VDC: 412 Amp.
Maximum Consumption in Sinusoidal Signal (1kHz) @ 12.6VDC: 826 Amp.
Dimensions (WxHxD): 9.02" X 2.56" X 19.57"
Weight: 13.47lbs
T-Line
This is the Platinum Series dedicated to Insanely High Efficiency Levels and Output Power.
The following amps only come in 1ohm stabiity with the exception of the T500D which has a 1 or 2ohm model.
Markings with "unofficial" next to them mean they were NOT provided by Taramp's and have been calculated to give you an estimated expected result.
T500D-
- Number of Channels - 1
- Class of Operation - (D)
- Pot. Max. @ 13.8VDC - 1 OHM - 599 WRMS
- Pot. Max. @ 13.8VDC - 2 OHMS - 359 WRMS
- Pot. Max. @ 13.8VDC - 4 OHMS - 197 WRMS
- Pot. Max. @ 12.6VDC - 1 OHM - 500  WRMS
- Pot. Max. @ 12.6VDC - 2 OHMS - 300 WRMS
- Pot. Max. @ 12.6VDC - 4 OHMS - 165 WRMS
- Input Sensitivity - 160mV (With Level to 100 %)
- Efficiency 1ohm model- 78%
- Efficiency 2ohm model- 87%
- Total Harmonic Distortion (THD) - 0.5%
- Signal / Noise Ratio: >90dB
- Damping Factor - 300
- Frequency Response - 20Hz to 30KHz (-3dB)
- Crossover Variable
High Pass - 100Hz to 2.2KHz (-12db/ 8nd ) Variable
Low Pass - 100Hz (-12dB/ 8nd ) Fixed
Bass Boost - 0 to 10dB (50Hz)
- Input Impedance - 18K OHMS
- Protection: Short on the Output and High / Low Voltage
- Minimum Supply Voltage - 10.5VDC
- Supply Voltage Maximum - 15VDC
- Consumption at Rest - 0.72 Amp.
- Cons. Maximum Musical @ 12.6VDC - 22 Amp.
- Cons. Maximum Sine Wave Signal (100Hz) @ 12.6VDC - 44 Amp.
- Dimensions (WxHxD) - 8.27" x 6.61" x 2.05"
- Weight - 2.65lbs
T10.9KW-
- Pot. Max. @ 13.8VDC - 1 OHM - 12890 WRMS- unofficial
- Pot. Max. @ 13.8VDC - 2 OHMS - 9255 WRMS- unofficial
- Pot. Max. @ 13.8VDC - 4 OHMS - 5767 WRMS- unofficial
- Pot. Max. @ 12.6VDC - 1 OHM - 10900  WRMS
- Pot. Max. @ 12.6VDC - 2 OHMS - 7848 WRMS
- Pot. Max. @ 12.6VDC - 4 OHMS - 4905 WRMS
- Input Sensitivity - 300mV - 6V (With Level to 100 %)
- Efficiency @ 1ohm- 78% - unofficial
- Total Harmonic Distortion (THD) - 0.3%
- Damping Factor - 250
- Frequency Response - 5Hz to 5KHz (-3dB)
High Pass - 5Hz - 50Hz (-12db/ 8nd ) Variable
Low Pass - 50Hz - 5KHz (-12dB/ 8nd ) Variable
- Input Impedance - 22K OHMS
- Protection: Short on the Output, High / Low Voltage, Excessive Clipping
- Consumption at Rest - 4.5 Amp.
- Cons. Maximum Musical @ 12.6VDC - 550 Amp.
- Cons. Maximum Sine Wave Signal (100Hz) @ 12.6VDC - 1100 Amp.
- Dimensions (WxHxD) - 11.46" x 2.2" x 24.88"
- Weight - 22.71lbs
T14.2KW-
- Pot. Max. @ 13.8VDC - 1 OHM - 16800 WRMS- unofficial
- Pot. Max. @ 13.8VDC - 2 OHMS - 10490 WRMS- unofficial
- Pot. Max. @ 13.8VDC - 4 OHMS - NA
- Pot. Max. @ 12.6VDC - 1 OHM - 14200  WRMS
- Pot. Max. @ 12.6VDC - 2 OHMS - 8890 WRMS
- Pot. Max. @ 12.6VDC - 4 OHMS - NA
- Efficiency @ 1ohm- 81% - unofficial
- Damping Factor - 200
- Consumption at Rest - 6 Amp.
- Cons. Maximum Musical @ 12.6VDC - 700 Amp.
- Cons. Maximum Sine Wave Signal (100Hz) @ 12.6VDC - 1400 Amp.
- Dimensions (WxHxD) - 11.46" x 2.2" x 28.74"
- Weight - 29.76lbs
T20.2KW-
- Pot. Max. @ 13.8VDC - 1 OHM - 23800 WRMS- unofficial
- Pot. Max. @ 13.8VDC - 2 OHMS - 14910 WRMS- unofficial
- Pot. Max. @ 12.6VDC - 1 OHM - 20200  WRMS
- Pot. Max. @ 12.6VDC - 2 OHMS - 12645 WRMS
- Efficiency @ 1ohm- 89% - unofficial
- Consumption at Rest - 9 Amp.
- Cons. Maximum Musical @ 12.6VDC - 905 Amp.
- Cons. Maximum Sine Wave Signal (100Hz) @ 12.6VDC - 1811 Amp.
- Weight - 31.09lbs
Edited by shizzzon
TL Line-
The TL Line amplifiers are lightweight. This line has models of amplifiers of 1 channel (mono), 2 channels (Stereo) and Three Channels, two for stereo and one for substage.
TL500-
Number of Channels - 2
Maximum Power @ 14.4 VDC - 2x50W RMS (Stereo 2 OHMS)
Power Supply Voltage: 8 to 16 VDC
Maximum Power Consumption (Musical): 3.8 Amp.
The Maximum Power Consumption (Sine): 7.6 Amp.
Frequency Response (-3dB): 80Hz ~ 40KHz
Input Impedance: 1K OHM
Output Impedance: 2 OHMS
System of Protection: Short outlet / Thermal Protection
Dimensions (WxHxD): 3.5" x 1.14" x 4.69"
Weight: 0.22lbs
TL600-
- Number of Channels - 2
- Maximum Power @ 13.8 VDC - 2Ω - 170 WRMS (2 x 85W)
- Maximum Power @ 13.8 VDC - 4Ω - 120 WRMS (2 x 60W)
- Input Sensitivity - 1.5V
- Total Harmonic Distortion (THD) - >0.05%
- Frequency Response - 50Hz to 50Khz (-3dB)
- Efficiency - >80%
- Input Impedance - 1K OHM
Thermal Protection and Short on the Output
- Minimum Supply Voltage - 10VDC
- Supply Voltage Maximum - 16VDC
- Average Consumption at Rest - 350 mA
- Maximum Consumption Musical @ 13.8VDC - 8A
Maximum Consumption in Sine Wave Signal (1KHz) @ 13.8VDC - 16.5A
- Dimensions (WxHxD) - 5.2" x 1.57" x 3.94"
- Weight - 0.82lbs
TL900-
Maximum Power @13.8 VDC - 2 OHMS - 300W RMS
Maximum Power @13.8 VDC - 4 OHMS - 184W RMS
Maximum Power @13.8 VDC - 8 OHMS - 114W RMS
Configurations to 13.8 VDC
1 Channel - 1 x 300W RMS Mono (2 OHMS)
Input Sensitivity
Input RCA = 250mV (with the level to 100 %)
Entry of wire = 1.5V (with the level to 100 %)
Total Harmonic Distortion (THD) - 0.45%
Damping Factor - >200
Frequency Response (Full Range): 10Hz to 40KHz (-1dB)
H. P. F (High Pass Filter) - Fixed: 80Hz (-12dB/ 8nd )
L. P. F (Low Pass Filter) - Fixed: 80Hz (-12dB/ 8nd )
Efficiency: 80%
Input Impedance:
18K  OHMS (RCA)
1.8K OHMS (Wire)
Minimum Supply Voltage: 9 VDC
Consumption at rest: 550 mA.
Maximum Consumption Musical @ 13.8VDC: 15 Amp.
Maximum Consumption in Sinusoidal Signal (1KHz) 13.8VDC: 30 Amp.
Dimensions (WxHxD): 5.28" x 1.65" x 5.35"
Weight: 0.99lbs
TL1200-
Maximum Power @13.8 VDC - 2 OHMS - 260W RMS
Maximum Power @13.8 VDC - 4 OHMS - 160W RMS
Maximum Power @13.8 VDC - 8 OHMS - 100W RMS
2 Channels - 2 X 130W RMS (Stereo 2 OHMS)
1 Channel - 1 X 260W RMS (Bridged 4 OHMS)
Input Sensitivity
Total Harmonic Distortion (THD) - 0.05%
Separation between Channels (Crosstalk): .45dB
Damping Factor - >300
Frequency Response (Full Range): 10Hz to 21KHz (-1dB)
Efficiency: 78%
Input Impedance:
22K  OHMS (RCA)
1K OHMS (Wire)
Protection: Short outlet, Thermal Protection
Minimum Supply Voltage: 8 VDC
Consumption at rest: 900 mA.
Maximum Consumption Musical @ 13.8VDC: 12.5 Amp.
Maximum Consumption in Sinusoidal Signal (1KHz) 13.8VDC: 25 Amp.
Weight: 0.99lbs
TL1500-
Number of Channels - 3
- 1 X 200W RMS ( SUB 4 OHMS)
- 2 x 95 W RMS (STEREO 2 OHMS)
Input Sensitivity
Input RCA = 160mV
Input wire = 1.5V
Frequency Response
Output of Sub: 15Hz to 100Hz with a cut-off frequency active (12dB/ 8nd )
Outputs Stereo L/R: 100Hz to 30KHz with a cut-off frequency active (12dB/ 8nd )
Bass Boost - Adjustable from 0 to 10dB @ 50Hz
Efficiency- >90%
Input Impedance - 22K OHMS (RCA) | 1K OHMS (Wire)
Protection - Thermal and Short Outlet
Minimum Supply Voltage - 8VDC
Consumption at Rest - 1 Amp.
Maximum Consumption Musical @ 13.8VDC - 18 Amp.
Maximum Consumption in Sinusoidal Signal (1KHz) 13.8VDC - 36 Amp.
Dimensions (WxHxD) - 5.28" x 1.65" x 7.4"
Weight: 1.83lbs
TL1800-
- 2 x 85 W RMS (STEREO 2 OHMS)
- 1 X 360W RMS ( SUB 2 OHMS)
Input Sensitivity:
RCA Input = 250mV
Input wire = 6.0V
Total Harmonic Distortion (THD): 0.05%
Signal/Noise Ratio: >90dB
Damping Factor: >300
Sub: 10Hz to 90Hz with a cut-off frequency active (-12dB/ 8nd )
Outputs Stereo L/R: 90Hz to 30KHz with a cut-off frequency active (-12dB/ 8nd )
Bass Boost: Adjustable from 0 to 10dB @ 50Hz
Efficiency: >80%
Input Impedance:
- 10K OHMS (RCA)
- 1K OHMS (WIRE)
Protection: Short on the Output / thermal Protection
Minimum Supply Voltage: 8VDC
Supply Voltage Maximum: 16VDC
Consumption at Rest: 1.3 Amp.
Maximum Consumption Musical @ 13.8VDC: 25 Amp.
Maximum Consumption in Sinusoidal Signal (1KHz) 13.8VDC: 50 Amp.
Dimensions (WxHxD): 5.28" x 1.77" x 10.28"
Weight: 2.43lbs
Edited by shizzzon
TS Line-
This line of amplifiers come in 2 or 4 channels and 1 5 channel.  These amps come in 1ohm or 2ohm stability models and all ratings below are of 1ohm model. Expect slightly higher efficiency with 2ohm models.  The 5 channel only comes in one version.
All amps in the TS line use FIXED Crossover points.
TS150x2-
- Class of operation - (D)
- maximum Power @ 13.8 VDC (2 OHMS) - 150 WRMS (2x75W)
- maximum Power @ 13.8 VDC (4 OHMS) - 90 WRMS (2x45W)
- maximum Power @ 13.8 VDC (8 OHMS) - 50 WRMS (2x25W)
- Configuration:
2 x 75 Watts - 2 OHMS
1 x 150 Watts - 4 OHMS (Bridge)
- Input Sensitivity - 320mV to 3.2V
- Total Harmonic Distortion (THD) - > 0.05%
- Separation between Channels (Crosstalk) - > 47dB
- Signal / Noise Ratio - > 90dB
- Damping Factor - > 180
- Frequency Response - 18Hz to 40KHz (-1dB)
- Fixed:
High Pass Crossover - 100Hz (-12db/ 8nd )
Low Pass - 100Hz (-12db/ 8nd )
Full Range (18Hz to 40KHz)
- System of Protection: Thermal and Short outlet
- Consumption at Rest - 530mA
- Cons. Max. Musical @ 13.8 vdc - 7Amp.
- Cons. Max. with Sinusoidal Signal (1KHz) @ 13.8vdc - 13.5Amp
- Dimensions (WxHxD) - 6.54" x 2.01" x 3.62"
- Weight - 1.12lbs
TS400x4EF-
Number of Channels - 4
Automatic remote Actuation (No Remote terminal!)
Power Max. @ 13.8 VDC - 2 OHMS - 400 W RMS (4X 100W RMS)
Max. Power @ 13.8 VDC - 4 OHMS - 252 W RMS (4 X 63W RMS)
Max. Power in Bridged @ 13.8 VDC - 4 OHMS - 400W RMS (2 X 200W RMS)
Input Sensitivity: 6V
Frequency Response (Full Range): 20Hz to 30KHz (-1dB)
Crossover
H. P. F (High Pass Filter): fixed 90Hz(-12dB/ 8nd )
L. P. F (Low Pass Filter): fixed 90Hz(-12dB/ 8nd )
Efficiency the Output Stage: >90%
Input Impedance: 1K OHMS
System of Protection - Thermal and Short on the Output
Voltage of Maximum Power: 16VDC
Consumption at Rest: 1 Amp.
Maximum Consumption Musical @ 13.8VDC: 19 Amp.
Maximum Consumption In Sinusoidal Signal (1KHz) 13.8VDC: 38 Amp.
Dimensions (WxHxD): 5.28" x 1.65" x  7.99"
Weight: 1.96lbs
TS600x4-
Number of Channels: 4
Maximum Power @ 13.8 VDC - 2 OHMS: 720W RMS
Maximum Power @ 13.8 VDC - 4 OHMS: 432W RMS
Maximum Power @ 13.8 VDC - 8 OHMS: 240W RMS
Maximum Power @ 12.6 VDC - 2 OHMS: 600W RMS
Maximum Power @ 12.6 VDC - 4 OHMS: 360W RMS
Maximum Power @ 12.6 VDC - 8 OHMS: 198W RMS
Settings @ 12.6 VDC:
4 Channels - 4 X 150W RMS - 2 OHMS
3 Channels - 2 X 150W RMS - 2 OHMS
1 X 300W RMS - 4 OHMS - BRIDGE
2 Channels - 2 X 300W RMS - 4 OHMS - BRIDGE
Input Sensitivity: 160mV (With the Level The 100 % .)
Total Harmonic Distortion (Thd): 0.45%
Separation between Channels (Crosstalk): >60dB
Signal/Noise Ratio: >95dB
Damping Factor: >200
Crossover:
H. P. F (High Pass Filter) fixed: 100Hz(-12dB/ 8nd )
L. P. F (Low Pass Filter) fixed: 100Hz(-12dB/ 8nd )
Efficiency: 80%
System of Protection: Short in supply Voltage Output / High / Low
Minimum Supply Voltage: 9VDC
Consumption dm Rest: 1.20 Amp.
Maximum Consumption Musical @ 12.6vdc: 30 Amp.
Maximum Consumption in Sinusoidal Signal (1khz) 12.6vdc: 60 Amp.
Dimensions (WxHxD): 6.61" x 2.13" x 10.04"
Weight: 3.35lbs
TS800x4-
Number Of Channels - 4
Max. Power @ 13.8 VDC - 1 OHMS: 960W RMS (4X 240W RMS)
Max. Power @ 13.8 VDC - 2 OHMS: 600W RMS (4X 150W RMS)
Max. Power @ 13.8 VDC - 4 OHMS: 288W RMS (4 X 72W RMS)
Max. Power @ 12.6 VDC - 1 OHMS: 800W RMS (4X 200W RMS)
Max. Power @ 12.6 VDC - 2 OHMS: 500W RMS (4X 125W RMS)
Max. Power @ 12.6 VDC - 4 OHMS: 242W RMS (4 X 60W RMS)
Pot. Max. in Bridged @ 13.8 VDC - 2 OHMS: 960W RMS (2 X 480W RMS)
Pot. Max. in Bridged @ 13.8 VDC - 4 OHMS: 648W RMS (2 X 324W RMS)
Pot. Max. in Bridged @ 12.6 VDC - 2 OHMS: 800 WRMS (2 X 400W RMS)
Pot. Max. in Bridged @ 12.6 VDC - 4 OHMS: 540 WRMS (2 X 270W RMS)
Input Sensitivity: 160mv (With The Level To 100 % .)
Separation between Channels (Crosstalk): >45db
Signal/Noise Ratio: >90db
Damping Factor: >250
Frequency Response (Full Range): 20Hz TO 40khz (-1db)
Crossover:
H. P. F (High Pass Filter) fixed: 100Hz(-12db/ 8nd )
L. P. F (Low Pass Filter) fixed: 100Hz(-12db/ 8nd )
Bass Boost (Channels 3 and 4): 0 To 10db (50Hz)
Efficiency: 78%
System of Protection: Short Outlet / Supply Voltage High/low
Minimum Supply Voltage: 10VDC
Consumption at Rest: 850ma.
Maximum Consumption Musical @ 12.6vdc: 42.5 Amp.
Maximum Consumption in Sinusoidal Signal (1khz) 12.6VDC: 85 Amp.
Dimensions (WxHxD): 7.68" X 2.2" X 12.44"
Weight: 5.18lbs
TS1200x4-
- Number of Channels - 4
- Pot. Max. @ 13.8VDC (1 OHM) - 1440 W RMS (4x360W RMS)
- Pot. Max. @ 13.8VDC (2 OHMS) - 950W RMS (4x237W RMS)
- Pot. Max. @ 13.8VDC (4 OHMS) - 522 W RMS (4x130W RMS)
- Pot. Max. @ 12.6VDC (1 OHM) - 1200 W RMS (4x300W RMS)
- Pot. Max. @ 12.6VDC (2 OHMS) - 792W RMS (4x198W RMS)
- Pot. Max. @ 12.6VDC (4 OHMS) - 435 W RMS (4x109W RMS)
- Pot. Max. in Bridged @ 13.8VDC (2 OHMS) - 1440W RMS (2x720W RMS)
- Pot. Max. in Bridged @ 13.8VDC (4 OHMS) - 972W RMS (2x486W RMS)
- Pot. Max. in Bridged @ 12.6VDC (2 OHMS) - 1200W RMS (2x600W RMS)
- Pot. Max. in Bridged @ 12.6VDC (4 OHMS) - 810W RMS (2x405W RMS)
- Bass Boost (Channels 3 and 4) - 0 to 10dB (50Hz)
- Input Sensitivity - 160mV (With the Level to 100 % .)
- Total Harmonic Distortion (THD) - > 0.5%
- Separation between Channels (Crosstalk) - > 45dB
- Signal-to-Noise Ratio - > 90dB
- Damping Factor - 350
- Frequency Response (Full Range) - 20Hz to 30kHz (-1dB)
- Crossover:
H. P. F (High Pass Filter) - Fixed 100Hz (-12db/ 8nd )
L. P. F (Low Pass Filter) - Fixed 100Hz (-12db/ 8th)
- Input Impedance - 18k OHMS
- Protection: Short on the Output and Supply Voltage High / Low -
- Consumption at Rest - 1.80 Amp.
- Cons. Maximum Musical @ 12.6VDC - 65 Amp.
- Cons. Maximum with Sinusoidal Signal (1KHz) @ 12.6VDC - 130Amp.
- Dimensions (WxHxD) 7.68" x 2.2" x 14.25"
- Weight - 6.06lbs
TS1300x2-
Number of channels - 2
maximum Power @ 13.8 VDC - 1 OHM: 1559W RMS
maximum Power @ 13.8 VDC - 2 OHMS: 935W RMS
maximum Power @ 13.8 VDC - 4 OHMS: 514W RMS
maximum Power @ 12.6 VDC - 1 OHM: 1300W RMS
maximum Power @ 12.6 VDC - 2 OHMS: 780W RMS
maximum Power @ 12.6 VDC - 4 OHMS: 429W RMS
Configurations to 12.6 VDC
2 channels - 2 X 650W RMS 1 OHM -
1 channel - 1 X 1300W RMS - 2 OHMS (BRIDGED)
input Sensitivity: 160mV (With the Level to 100 %)
Total Harmonic Distortion (THD): 0.45%
Separation between channels (crosstalk): >70dB
Signal/Noise Ratio: >92dB
damping Factor: >350
frequency Response (FULL  RANGE): 15Hz to 38KHz (-1dB)
Crossover:
Bass boost (Channels 1 and 2): 0 to 10dB (50Hz)
Efficiency: 80%
System of protection: Short outlet / supply Voltage high/low
minimum supply Voltage: 9VDC
supply Voltage: 16VDC maximum
Consumption at rest: 1.20 Amp.
Maximum Consumption musical @ 12.6VDC: 63.7 Amp.
Maximum Consumption in sinusoidal signal (1KHz) 12.6VDC: 128 Amp.
Dimensions (WxHxD): 7.68" x 2.2" x 12,2"
Weight: 4.87lbs
TS700.5D-
Number of channels 05
Channels Front / Rear
Max. Power 13.8 VDC - 2 OHMS 100W RMS
Max. Power 13.8 VDC - 4 OHMS 60W RMS
Max. Power 13.8 VDC - 8 OHMS 40W RMS
Channel SUB
2 OHMS 300W RMS
4 OHMS 180W RMS
8 OHMS 120W RMS
5 Channels 4 x 100W RMS - 2 OHMS 1 x 300W RMS - 2 OHMS
3 Channels 2 x 200W RMS - 4 OHMS 1 x 300W RMS - 2 OHMS
Input Sensitivity 140mV. (With level to 100 %)
Frequency Response 20Hz to 20KHz (-1dB) 30Hz to 300KHz (-3dB)
Bass Boost 0 to 18dB (45Hz)
H. P. F (High Pass Filter) Variable 15Hz to 250Hz (-12dB/ 8)
L. P. F (Low Pass Filter) Variable 30Hz to 300KHz (-12dB/ 8)
Dimensions (LxWxH) 12.01" x 6.93" x 2.01"
Weight: 4.66lbs
Edited by shizzzon
Accessories-
Antenna-
TFM1080i-
The TFM 1080i Antenna has a universal application.  It can be installed in any vehicle, secured by double-sided tape, developed with high performance, active circuitry that ensures clean reception, free of interference and noise. Great signal reception from AM and FM. Its design comes from meeting with the market trend, lightweight and discreet.
TFM 1080i antenna universal electronic windshield printed Rod 10.25"
SMD Technology amplified
8' 6" Cable from the antenna
Connector in brass surface treated to eliminate oxidation
Red LED
Connection PLUG DIN
Universal Application, can be installed in any vehicle
Wireless Transmission-
TW-Master/Slave-
CHARACTERISTICS OF the TRANSMITTER (TW-MASTER):
Operational Range of Radio Frequency: 2.4GHz ISM band (2.404GHz to 2.476GHz)
Maximum Power of RF transmission: 20.2dBm (105mW)
Connectivity: Up to 4 receivers (Slave)
Input Impedance: 10K ohms audio (RCA) and 1K ohms (WIRE)
Maximum Level of audio input L/R (RCA): 2V RMS ( 8dBu)
Frequency Response: 10Hz to 22KHz (-1dB)
Total Harmonic Distortion (THD): 0.01% the 1KHz
Crosstalk (separation between channels): >80dB
Power supply Voltage: 10 to 16V DC
Maximum Consumption: 160mA @12.6
Consumption in Stand-by: 10mA
Protection: resettable thermal fuse (PPTC), internal protection against polarity reversal
Dimensions (WxHxD): 3.47: x 1.18" x 4.65"
Weight: 0.22lbs
CHARACTERISTICS OF RECEIVER (TW-slave):
Output Impedance: 470 ohms audio
Output level of audio L/R: 2V RMS
Nominal Consumption: 100mA @12.6
Consumption in Stand-by: 40mA
Maximum Current output from remote: 250mA
Dimensions (WxHxD): 3.47" x 1.18" x 4.65"
Weight: 0.22lbs
Voltmeter-
VTR-1200-
Innovative Digital Voltmeter
Unique design, lightweight, transparent, functional and practical; very easy to be installed.
Displaying BLUE showing the mark of innovation that TARAMPS provides to its consumers.
For its connection, the connector system is detachable facilitating ease of installation.
Technical Data:
Voltage Range: 10.2 to 27V DC
Maximum Current output remote (OUT) 650mA
Maximum current Consumption: 60mA
Dimensions: 4.72" X 3.47" X 1.18"
Weight: 0.22lbs
RCA Cables-
RCA+ Twisted-
- Cancellation of noise due to the construction of twisted pairs signals that improves the CMRR (Common Mode Rejection Ratio) Index of Common-Mode Rejection
- Great driving signal due to its construction continues of connectors
- Logotype Taramps in low relief showing the quality of the product
- RCA Connectors ultra compact and bicolor to facilitate identification at the time of installation
- Tip of the RCA connector closed for better signal transfer
- The Drivers 2x0,12mm² in copper OFHC (Oxygen Free High Thermal Conductivity) high thermal conductivity - free of oxygen
- External Cover translucent with double insulation in PVC (Polyvinyl chloride) offers flexibility
These cables come in the following models-
15"- 2 Male In, 2 Male Out
78"- 1 Female In, 2 Male Out
39"- 1 Male In, 2 Female Out
196"(16 1/3 FT)- 2 Male In, 2 Male Out
RCA High Grade-
INNER CONDUCTOR
Coper Wire Rope- 0.20mm2 - for systems that require greater flexibility and low ohm resistance of the inner conductor
oxygen-free copper (OFC) with purity greater than 99% and nominal resistivity of 1.274 x 10-6 (ohm/cm) at 20C
lower resistance results in increase in driving the signal;
Dielectric Insulation
The main element of the coaxial cable, because the electromagnetic wave walks inside the dielectric to transmit the signal by the inner conductor
EXTERNAL CONDUCTOR (SHIELD)
Double braided shield; bare copper with 128 wires of 0.127mm2
Semiconductor Polymer, conductive material carbon-based;
COVER OR EXTERNAL COVER
Provides the protection of the cable against the external environment
PVC (Polyvinylchloride) - offers flexibility
CONNECTORS
Manufactured brass plated CLA in nickel offering a great driver of the signal and has cavities with high pressure.
The spring has the function to increase flexibility and not to damage the cable.
39"- 1 Male In, 1 Male Out
39"- 2 Male In, 2 Male Out
118"(9 3/4 FT)- 2 Male In, 2 Male Out
Equalizers-
DEQ-1000-
Frequency Selection:
15 Bands separated by 2/3 octave (25Hz, 40Hz, 63Hz, 100Hz, 160Hz, 250Hz, 400Hz, 630Hz,
1KHz, 1.6KHz , partials close , 6.3KHz , 4KHz, 10KHz, 16KHz) Mitigation
/ Enhancement: up to 12dB in steps of 0.5dB
Signal / Noise Ratio: >100 dB
Crosstalk (separation between channels): >85dB
THD: < 0.01%
Frequency Response: 15Hz to 23KHz (-3dB)
Maximum Level of Input Signal: 2.0V RMS
Maximum Level of Output Signal: 2.0V RMS
Input Impedance: 22K OHMS
Output Impedance: 330 OHMS
Operating Voltage: 8V to 16V DC
Maximum Consumption: 400mA
Dimensions (WXHXD): 7.6" x 1.7" x 4.72"
Weight: 0.68lbs
Additional Functions:
Limiter with 6 levels of attenuation: (-3dB/ -6dB/ -9dB / -12dB / -15dB / -18dB)
Filter HPF (subsonic):  (Fc = 30Hz / 40Hz / 50Hz / 60Hz / 70Hz / 80Hz) with attenuation of
24dB/ 8nd
Filter LPF: (Fc = 500Hz / 1KHz / of 1.5khz / 2KHz / partials close ) with attenuation of 12dB/ 8nd
screen Saver with VU
VU Bargraph leds with TI CLIP
Edited by shizzzon
Crossovers-
CRX-2-
Channels - 2
Subsonic Filter: Variable Bypass /20/60/80Hz (-24dB/ 8deg  4deg  order Linkwitz-Riley )
Bass Boost: 0 to 10 dB (40Hz)
Low Pass Filter: Variable from 100Hz to 10KHz (-12dB/ 8deg 2deg order Butterworth)
High Pass Filter: Variable from 100Hz to 10KHz (-12dB/ 8deg 2deg order Butterworth)
Input Impedance: 27K ohms
Output Impedance: 440 ohms
Maximum Input L/R: 4.57 V RMS @ 15.4 dBu
Output Level L/R: 9.3 V RMS @ 21.6 dBu
Max. Output of the Pass Thru L/R: 9.3 V RMS @ 21.6 dBu
Frequency Response: (-1dB) of 10Hz to 100KHz
Total Harmonic Distortion (THD): < 0.01% at 1KHz
Crosstalk (Separation between channels): >90dB
Power Supply Voltage: 10 to 16 VDC
Nominal Consumption: 250mA @ 12.6 Vdc
Protection: Reverse Polarity and short circuit
Dimensions (WxHxD): 6.18" x 1.65" x 5.71"
Weight: 1.01lbs
CRX-3.1-
Channels - 3 + 1 Pass Thru
Channel Pass Thru (R L)
Phase Selectable: 0/180 Degrees
Variable Level: -infinity to 6dB
Via Low (R L) Mono
Subsonic Filter: Selectable on Bypass, 20/30/40Hz (-24dB/ 8nd) butterworth
Low Pass Filter: Selectable on Bypass, 80/150/250Hz (-12dB/ 8nd Linkwitz-Riley )
Bass Boost: Variable 0 to 10 dB (40Hz)
Variable Level: -infinity to 10dB
Track Mid (R and L) Stereo
High Pass Filter: Selectable on Bypass, 80/150/250Hz (-12dB/ 8nd Linkwitz-Riley )
Low Pass Filter: Selectable on Bypass, 1.2K/2K/4KHz (-12dB/ 8nd Linkwitz-Riley )
Track High (R and L) Stereo
High Pass Filter: Selectable in 900Hz/1.2K/2K/4KHz (-12dB/ 8nd Linkwitz-Riley )
Input Impedance: 10 K Ohms
Output Impedance: 470 Ohms
Maximum Input Level R/L: 4.57 V RMS @ ( 15.4 dBu)
Maximum Level of Output R/L: 9.3 V RMS @ ( 21.6 dBu)
Max Output Level of Pass Thru R/L: 9.3 V RMS @ ( 21.6 dBu)
Power Supply Voltage: 10.5 to 16 VDC
Nominal Consumption: 420mA @ 12.6 Vdc
Protection: Inversion of Polarity
Dimensions (WxHxD): 8.46" x 1.65" x 5.63"
Weight: 1.35lbs
CRX-4-
Electronic Crossover 12dB/ 8nd with 4 channels
LOW: With variable cut(LPF) from 45 to 275Hz and bass enhancement of 6dB ( "bass boost") adjustable from 20 to 65Hz
MID-LOW: With initial cut (HPF) variable from 25Hz to 140Hz and final cutting (LPF) variable from 300Hz to 7.5KHz
MID-HIGH: With initial cut (HPF) variable 200Hz to 4.6KHz and final cutting (LPF) variable of 1.2KHz to 12KHz
HIGH: With variable cut (HPF) of 550Hz to 12KHz
Individual level Controls for channel
Track LOW and MID-LOW mono, with independent inputs
Tracks HIGH AND MID-HIGH stereo, separated from inputs LOW and MID-LOW
Dimensions: 7.48" x 5.71" x 1.58" (L x W x H)
Weight: 1.24lbs
CRX-5 PLUS-
Quantity of channels - 4 + 1 Pass Thru
Track Pass Thru (R L)
Via Low (R L) Mono
Subsonic Filter: Selectable (Bypass 40/60/80Hz ) (-24dB/ 8nd) butterworth
Low Pass Filter: Variable from 100Hz to 2KHz (-12dB/ 8nd Linkwitz-Riley )
Via Low Mid (R L) Mono
High Pass Filter: Variable from 30Hz to 600Hz (-12dB/ 8nd Linkwitz-Riley )
Low Pass Filter: Variable from 600Hz to 10KHz (-12dB/ 8nd Linkwitz-Riley )
Track High Mid (R and L) Stereo
High Pass Filter: Variable from 400Hz to 3KHz (-12dB/ 8nd Linkwitz-Riley )
Low Pass Filter: Variable from 5KHz to 20KHz  (-12DB/ 8nd Linkwitz-Riley )
High Pass Filter: Variable from 2KHz to 10KHz (-12dB/ 8nd Linkwitz-Riley )
Input Impedance: 10K Ohms
Dimensions (WxHxD): 9.37" x 1.65" x 5.71"
Weight: 1.54lbs
DTX-2.4S-
Filters: Per DSP, 24-bit/ 48KHz, (-24dB/ 8th) - 4TH order (Butterworth)
VIA LOW (L/R)
cut-off Frequency (HPF): 9 preset adjustments 20/25/30/35/40/45/50/55/60Hz
cut-off Frequency (LPF): 19 preset adjustments 60/70/80/90/100/110/125/140/160/180/200/225/250/280/320/360/400/450/500Hz
TRACK LOW MID (L/R)
cut-off Frequency (HPF): 11 preset adjustments 60/70/80/90/100/110/125/140/160/180/200Hz
cut-off Frequency (LPF): 25 preset adjustments 200/225/250/280/320/360/400/450/500/570/640/720/800/900/1K/1.1K/1.2K/1.4K/1.6K/1.8K/2K/2.2K/2.5K/2.8K/3.2KHz
TRACK HI MID (L/R)
cut-off Frequency (HPF): 21 preset adjustments 200/225/250/280/320/360/400/450/500/570/640/720/800/900/1K/1.1K/1.2K/1.4K/1.6K/1.8K/2KHz
cutoff Frequency (LPF): 9 preset adjustments 5.1K/5.7K/6.4K/7.2K/8.1K/9.1K/10K/11K/12KHz
VIA HIGH (L/R)
cut-off Frequency (HPF): 17 preset adjustments 2K/2.2K/2.5K/2.8K/3.2K/3.6K/4K/4.5K/5.1K/5.7K/6.4K/7.2K/8.1K/9.1K/10K/11K/12KHz
Input Impedance: 18K ohms
Maximum Input L/R: 4.0 V RMS @ ( 14 Dbu)
Maximum Level of Output L/R: 4.0 V RMS @ ( 14 dBu)
Frequency Response: 20Hz to 23KHz (-3dB)
Nominal Consumption: 0.50A @ 12.6 Vdc
Dimensions (WxHxD): 9.76" x 1.65" x 5.32"
Weight: 1.52lbs
Additional Functions: Adjustments of phase, gain, alignment and mute
Power Supplies-
TEF-30A-
Dual voltage Power Supply: automatic (127 / 220V AC)
Operational range 127V: 100 to 140V AC
Operational range 220V: 200 to 240V AC
Rated Current max. output: 30 Amps
Efficiency: 85% Consumption
Maximum Current Draw 127V: 5.6 Amps
Maximum Current Draw 220V: 4.0 Amps
Maximum Floatation at full load (30A @ 12.6V): < 3%
Input Fuse (internal): 10A, quick action
Dimensions (WxHxD): 6.54" x 2.05" x 5.71"
Weight: 2.36lbs
TEF-50A-
Operational range 127V: 105 to 140V AC
Operational range 220V: 210 to 240V AC
Rated Current max. output: 50 Amps
Output Voltage (Selectable): 12.6/ 13.8v/ 14.4vDC
Maximum Current Draw 127V: 8.0 Amps
Maximum Current Draw 220V: 5.0 Amps
Maximum Floatation at full load (50A @ 12.6V): < 3%
Dimensions (WxHxD): 10.55" x 2.83" x 6.22"
Weight: 5.51lbs
TEF-100A-
Operational range 220V: 190 to 240V AC
Rated Current max. output: 100 Amps
Maximum Current Draw 127V: 16.5 Amps
Maximum Current Draw 220V: 12.8 Amps
Maximum Floatation at full load (100A @ 12.6V): < 3%
Protection Threshold against overload/ short outlet: 120A
Dimensions (WxHxD): 10.55" x 2.83" x 11.42"
Weight: 9.48lbs
All Products we can\will offer has been updated.
Taramp's also offers a 300mF cap we do not see a need to offer, several high voltage power supplies and several high voltage DC amplifiers(40-340vDC)
Because of the nature of how to supply to these amps, we do not stock these.
We may special order them but are never stocked.
