April 27, 201412 yr Author LOL- sorry- I blew them up to look at the connections, and noticed.good eye.All amp connections will be dual input 3/0 when it's done. I ran 6 runs from the front ans this is what I had left. I'll order more when I goes on sale again. I want 6 more runs back and to finish that last amp connection.
April 29, 201412 yr Author Now that it's playing. Roughly 11-12k. New meter should be here in a few days.Any predictions? 3 stock Ethos 15s, all caps, no batteries, 2 amps.Ready GO!
April 29, 201412 yr if it's below 150 don't even post any results.Lmao!!I bet its big numbers! Wouldnt doubt his goals at all.
April 29, 201412 yr Author if it's below 150 don't even post any results.Lmao!!I bet its big numbers! Wouldnt doubt his goals at all.goals and reality are far apart. Took me a year and a half to hit my 160 in the camaro. I too expect big numbers but I won't get anyone's hopes up.
April 29, 201412 yr Author These trucks fall out sealed up. It will be an Outlaw kick score. Good guess though.
May 1, 201412 yr Author Getting closer to test time. Subs back in and taped up. Decided to paint the tape to match the box so it's not so ugly.
May 1, 201412 yr Author very nice. when shall testing commence?initial testing hopefully this weekend. My meter showed up on Tuesday but I need to pick it up at the post office. Been real busy doing other things.
May 1, 201412 yr Very very well done. I scanned through. (work, so i can sit for to long) I was wondering if you got your dual set up?EDIT- and if i could possibly see/copy it? Im doing the same on my 4.3. Im using the AC comp spot. Ive milled out my brackets. I had a set back last week with a service light, starts/idle like poop. Replaced plugs, wires, cap and rotor, then fuel spider, and fuel press reg, and its back to brand new. (for me) I wish you luck. I was tagged on FB on seeing that B2.7 on the dyno they have, if that matters. But, it did GREAT pulls. I wish you best of luck, and i apologize for any questions asked that have been answerd that i missed. Ill go through the entire BL when i get home and get a beer in my hand. Cheers. Edited May 1, 201412 yr by Kylar96
May 1, 201412 yr Author Very very well done. I scanned through. (work, so i can sit for to long)I was wondering if you got your dual set up?EDIT- and if i could possibly see/copy it?Im doing the same on my 4.3. Im using the AC comp spot.Ive milled out my brackets. I had a set back last week with a service light, starts/idle like poop. Replaced plugs, wires, cap and rotor, then fuel spider, and fuel press reg, and its back to brand new. (for me)I wish you luck. I was tagged on FB on seeing that B2.7 on the dyno they have, if that matters. But, it did GREAT pulls.I wish you best of luck, and i apologize for any questions asked that have been answerd that i missed. Ill go through the entire BL when i get home and get a beer in my hand. Cheers.thank you!. No I am still using the factory location plus the A/C location. The bracket I want to fab, is to add a third alt next to the factory spot. I hav yet to do so.I likely won't do it until I move up in class to the unlimited class. I have restrictions in my class this year.
May 2, 201412 yr So the tape is only really beneficial if your doing spl? Does it make an audible difference in your opinion?
May 2, 201412 yr So the tape is only really beneficial if your doing spl?Does it make an audible difference in your opinion?Chasing tenths, no, not audible.
May 4, 201411 yr Author 158.8. Outlaw.One quick burp. That was the score. Head unit maxed out.have some things left to do and new pieces on the way.next score update should be over 160.
May 4, 201411 yr 158.8. Outlaw.One quick burp. That was the score. Head unit maxed out.have some things left to do and new pieces on the way.next score update should be over 160.nice!
