the orange or yellow strip would look good too in my opinion. but yours is the one that counts.
  • Replies 938
  • Views 87.6k
**** orange ! Good job on the 60+ !!
I'm not real keen on it.
Its not that bad really but the white divider looks 10x better in my opinion.
I agree. The white almost seems too bright.
I personally like the white. Never felt a 160. Bet that feels nice. Congrats!
Do you have a gray color you could try out?
Edited by jay-cee
I do. I originally did the whole truck gray. Looked like primer. Then I added the black. Then blue. Then white. Then orange. Lol
I actually tni k I'll try gray between the black and blue. That may set it off right where I like it.
First burp of the day.
Second burp of the day.
I'll stop there.
It's funny how the extended cab balloons and expands out during a burp. Enough to tear the heavy foil tape.
How is it at 30hz?
Probably not to good lol, if I remember correct its in a burp box tuned around 70 Hz
I'll stop there.
Insane, nice score.
Edited by SacredTanakh
Spl lab.
You have to buy the sensor still.
Any new goals with the truck since you surpassed your last one?
I would like to set a new world record. That was ultimately the goal with the camaro, but that project got terminated too early.
I guess numbers wise I should shoot for a 161 now. Then up it again. This truck has a ton of potential. At the end of the day I would love to see a 163+ out of it. Anyone that chases numbers knows that once you break over 160, the gains are far and few between.
Though I have a few tricks up my sleeve to get where I want to be. I have power limitations in my class and my amps are set just at clipping so there is nothing to gain there. Any other gains will have to come from the truck itself.
How is it at 30hz?
not the goal here. Though once I get the truck dialed in, I will be building a removable port extension so it will make for a good demo truck as well.
Well, you hit 60 with a SQ driver. Now we gotta wait and see what it'll do with an SPL driver.
SQ driver, lol. :P
Ball is in your court Sir.
Thats sorta my plan, run the Ethos loud and low till the SPL drivers come out. Then upgrade and see what kinda power I can run
I'm confident in the Ethos taking power. I say build as loud as you can.
Have you been able to bottom the subs out with that power Steve?
nope. Not trying either. I'm sure I could if I wanted.
