Looks like fun Steve!
Yeah, not so much. Hopefully it improves the score and it's not all for nothing.
  • Replies 938
  • Views 93.7k
Have you tried other sizes and/or turnings with the enclosure?
Nope. Biggest that will fit. Tuned at peak of vehicle.
Nope. Biggest that will fit. Tuned at leak of vehicle.
Will that always have the best results?
I guess it depends on goals. Always though, testing will tell you everything.
I was just wondering if you were going to test with different sizes or tuning to see if anything with the enclosure could help inprove your score
I think there is always things to improve upon.
I'm a noobie. I will be testing different things until the goals are reached.
50346d1399176557-power-saz-5000d-may03_0
some of the s10's have this bracket on the passenger side with the lower part that is almost a perfect fit for the ad244 with a slight elongation of bolt hole...
That's the smog pump.
I have a 4.3. But no smog pump. That's what that opening is used fir though.
yea,it was used on the fullsize trucks...it is a perfect spot for extra alt as it perfectly aligns the belt,and cost nothing but a little time to put one on vs. fabbing a bracket to hang off of...
I agree. Right now I'm limited to one alternator if I streetbeat. 2 if if stay with SS 751-1500. If I step up to SS unlimited. I'll try for 4 alternators.
I saw a 162.4 out of the same truck with the exact sane box style over the weekend. 3 dd motors with tantric soft parts. You definitely got some left to gain somewhere. Good luck! Nice build
Edited by Dangrebel
on how much power? There is 2 guys now doing 165 on gobs of power. I have small power.
For sure!
30k lol
not a bad score.  over twice the power and about 2 db higher than the scores steve showed yall
Edited by Quentin Jarrell
^^^^^^ What is this crap? ^^^^^^^
