Posted January 4, 201412 yr I will try to post pics soon. The question is has anyone ever installed the big 3 on this model of a vehicle. 2009 Ford Explorer 4.6Lt? I have been looking at my electrical and there is ll kinds of run offs from the positive wire from battery. There are 2 that run from positive into the fuse box, and at least 2 more that split off into I haven't found where yet. Seem like a lot. My question is would it be OK to keep those running to where they are going and still run 0 gauge from Alt to battery using a bus bar or similar? Also with the ground question there are several split offs from the ground battery terminal to the chasey, should just through those on top of my 0 gauge ground? Thanks
January 4, 201412 yr Author Yes leave stock wires intact and just add wires to complete the Big 3Some reason my pics arent loading. As for the Alt it has a run off from wire to a sensore, then to battery, should I just keep all them running and just add the 0 gauge on top ?Thanks
January 5, 201412 yr I have your truck (07). Just go ahead and leave factory wires there and just add on.
January 6, 201412 yr Author I have your truck (07). Just go ahead and leave factory wires there and just add on.OK great! Good look-in out.
