February 27, 201412 yr that sucks man... can you link the RCAs Sen??? curious looking at the thickness of them both damaged in shipping? damyeah, cosmetic, but still. Paying that much you would think shipping would have been better.
February 27, 201412 yr Author that sucks man... can you link the RCAs Sen??? curious looking at the thickness of them both damaged in shipping? damyeah, cosmetic, but still. Paying that much you would think shipping would have been better. They will be available in the store soon.
March 17, 201412 yr looks good. won't mounting to the door trim cause a lot rattles?I think it's screening into the metal door skin when mounted
March 17, 201412 yr Author There is about 8 mounts drilled in around the pod and door that will join the two together. The pod itself will absorb most of the energy.
March 17, 201412 yr looks good. won't mounting to the door trim cause a lot rattles?Attaching a ported enclosure to a door that is well "padded" should be fine.
March 17, 201412 yr There is about 8 mounts drilled in around the pod and door that will join the two together. The pod itself will absorb most of the energy. looks good. won't mounting to the door trim cause a lot rattles?Attaching a ported enclosure to a door that is well "padded" should be fine. oh so these will be ported then? looked IB in the pics.
March 17, 201412 yr Author There is about 8 mounts drilled in around the pod and door that will join the two together. The pod itself will absorb most of the energy. looks good. won't mounting to the door trim cause a lot rattles?Attaching a ported enclosure to a door that is well "padded" should be fine. oh so these will be ported then? looked IB in the pics. Not sure what technically these will be in. No, their not designed to be ported, but in the door, I suppose it's either a sealed enclosure, about 2cuft, or a leaky sealed. The 12s are mounted onto about a 3" thick wood ring, in addition to be wrapped in extremely heavy fleece that is then layed down with fiber. Then, the enclosure if mounted with several full threaded bolts on the back side to make the panel a once piece.
March 17, 201412 yr Obviously I didn't recall right from earlier in the thread. Those drivers really want to be ported so I figured and remembered that you were going to.
March 17, 201412 yr Author Obviously I didn't recall right from earlier in the thread. Those drivers really want to be ported so I figured and remembered that you were going to. Yeah, I would have wanted that optimally! Just, was unable to fit the space. I will post up a FR Graph soon, after SBN, I will continue this thread to be update with results.
March 20, 201411 yr Author looks nice, what material did you use? swede? Thanks Brandon! Yeah we used swede. I haven't seen them in person yet, currently at work LOL. I am anxious, and they are finished just in time. Tweeking will be done after SBN as we are already cutting it really close! Leaving tomorrow for Florida. SQ competition for me won't begin until the 12th of next month most likely.
March 20, 201411 yr i'd be interested in seeing how the grills were made if you can get some pics later.
March 20, 201411 yr Author i'd be interested in seeing how the grills were made if you can get some pics later. Sure thing.
