Posted January 13, 201412 yr I have heard a lot about welding supply and coppercableman on e-bay, what about wire and supply or electron beam (EB-flex) wire? Also I see that 1/0 welding wire in general is rated for 350 amps at 50 feet while 2/0 is rated for 400 amps at 50 feet. I don't expect more than a 20 foot run at most from my front to back battery so what size cable would you guys recommend for a Crescendo BC3500d at one ohm with a 300 amp external fuse rating? Lastly I notice there is an ultraflex cable available from welding supply (as well as directwireusa.com) that claims to contain 4x the strand count of the standard wire yet the amperage ratings are the same?
January 13, 201412 yr Welding cable is international standard. Awg is a standard. They "should" all be the same with the difference being in price, and the jacket
January 13, 201412 yr it"s worth getting the higher strand count....it is more flexible and easier to install some of the cheeper welding cable has a real cheep jacket on it that is easilydamaged
January 13, 201412 yr Go to your local welding supply shop and put your hands on some ... I usually cut my desired lengths and take them back to get connectors installed. Those old welders might not know what your intended use is but DANG do they know how to install a good connector ...
January 13, 201412 yr Go to your local welding supply shop and put your hands on some ... I usually cut my desired lengths and take them back to get connectors installed. Those old welders might not know what your intended use is but DANG do they know how to install a good connector ...Buy a torch and do it yourself , it's cheap, easy, fast and strong. Heat the connector from the back side, touch solder on the inside so it starts to melt, stop until it starts to get out of the bottom.It is preferred the terminal is snug, oh, and wear gloves and eye protection.
January 14, 201412 yr weldingsupply.com My buddy in Japan is doing a build and I told him to try the Ultra Orange Flex 2/0 and he said it was sexy with a high strand count. They also have clearance sales on pre-cut lengths where you can save a good amount of $$$.
January 14, 201412 yr I've used welding supply and the EB stuff. Yes the EB has less strand cound but both contain he same surface area therefore both within spec standards. The EB flex however is a good bit cheaper. I have found that the EB wire does not have any micro ban additive in the rubber to keep mold from growing on the jacket if that would be a problem
January 14, 201412 yr I've used welding supply and the EB stuff. Yes the EB has less strand cound but both contain he same surface area therefore both within spec standards. The EB flex however is a good bit cheaper. I have found that the EB wire does not have any micro ban additive in the rubber to keep mold from growing on the jacket if that would be a problemgood to know. THx
January 14, 201412 yr Below is 2/0 EB Flex. The discoloration is mold. It has been sitting under a covered car port for about 6 months.
January 14, 201412 yr Every so often EB flex has sales on their large wire as well. I've used them multiple times, great wire at an awesome price.
January 14, 201412 yr Link to pricing for the EB flex please? Myself & a few team members are considering a large order of wire in various sizes.....from as large as 4/0 to as small as 8g
January 14, 201412 yr the jacket on the EB flex does slide a bit, some people use glue i use marine glue lined heat shrink at the cut to prevent sliding
January 14, 201412 yr the jacket on the EB flex does slide a bit, some people use glue i use marine glue lined heat shrink at the cut to prevent slidingYep they use a cotton lining between the copper and jacket. Remember. Welders are using this stuff to weld over several hundred feet. It needs something to help flex at that length.
January 15, 201412 yr Link to pricing for the EB flex please? Myself & a few team members are considering a large order of wire in various sizes.....from as large as 4/0 to as small as 8gHope this link works. This is where I see their sales and updated prices, as they update their wire price on a monthly basis as copper prices fluctuate. If you order enough you can get free shipping as well, which is pretty big when ordering something this heavy.https://www.facebook.com/pages/Electron-Beam-Technologies-Inc/122082121139733
January 30, 201412 yr Author I do wish I would have known about the mold issue before ordering...that stuffs no joke.
