January 31, 201412 yr Author Waiting on 1 last battery. Put an amp up without the bottom rack just to see what it will look like
February 1, 201412 yr Author How close are the top of the amps to the back glass? That looks tight!Ill post a pic tomorrow. It's about 3-4 inches
February 5, 201412 yr Author Any updates ? maybe this weekend. Had to focus on my education, so the truck gets pushed aside. I did order 2 more d1600's.
February 11, 201411 yr Author My 21st battery came in, also did a little work on the bus bars. Just ordered $80 worth of hardware lol, as well as some skyhigh 4ga and ring terminals. Polished 1 to see how I liked it, and I did. So the rest will be done soon
February 11, 201411 yr for polishing you if you have 6 inch grinder you can get polishing pads for it which would make you polishing much easier. or look at a scotch brite pad for the 6 inch pedestal grinder. it could be less time consuming
February 11, 201411 yr Author for polishing you if you have 6 inch grinder you can get polishing pads for it which would make you polishing much easier. or look at a scotch brite pad for the 6 inch pedestal grinder. it could be less time consuming. Unfortunately I do not have a bench grinder so I had to do it the long way lol.
March 11, 201411 yr Author First demo was sealed up inside my garage lol. Engine was off, dropped to 16.2v from 17.3 resting. It got pretty uncomfortable right before the light fell. http://youtu.be/FgeD0Q7fxFA
March 11, 201411 yr Author My demo next... looking good Myers, trunk is almost ready for SBNThanks J. Fly over, you can take it for the day.
March 12, 201411 yr Author I'll be there in a few days hoe!!! Damn, need the number.You driving or flying? Also, my 2nd alt came in today
