Posted January 24, 201411 yr I have a 1998 Mitsubishi eclipse rs. Yesterday I tried taking out the stock head unit and putting in my Sony after market. I realized I messed up the the stock wiring harness. The wires no longer are plugged into the harness plug, just out hanging. I tried starting the car and the engine doesn't turn over all I get it a weird clicking sound coming from the dash. Battery is fully charged, lights work, heat/ac work. What could be wrong??
January 24, 201411 yr Author I'm out eating right now if you give me a little bit I can. Much appreciated
January 25, 201411 yr Did you check all the fuses? Make sure any bare wires are covered? Possibly you bumped something in the process that isn't related? Did you unhook the battery when installing the stereo? possibly something near the battery that you bumped (wiring harness connector near the battery) or didn't hook back up. More input would help us help you.
January 25, 201411 yr Author Thanks guys I covered every wire so nothing was touching and UN plugged the battery and touched the positive wire to the negative post and left for 30 minutes hooked it back up and it started
