April 19, 201411 yr Author All volumes are net. You will find in most instances the volume of the port will exceed the net volume of the chamber itself.
May 1, 201411 yr BOOM! I think I found something guys haha So, this whole time, we've been referring to this enclosure design "sealed box into ported chamber, an 4th order bandpass. BUT, I think I found something. Doing a little google search, I found this site. http://www.mobileinformationlabs.com/HowTo-1Woofer-BoxPaid-New.htm Now, I'm not sure on it's accuracy, or creditably. But, it sounds good to me. Anyways, the box is called, Single reflex band pass Sealed enclosures that play into a tune enclosure that acts an s a low pass filter... This increases efficiency within the “pass band” or usable frequency range of the enclosure.Pros: Can be made very efficient within the pass-band”, can be designed for increased gain in a band of frequencies, increased power handling within the band.Cons: Distortion hard to hear so, it’s very easy to destroy woofers, increased gain designs sacrifice low end response, relatively large enclosures very difficult to design and build, very sensitive to design/construction errors. -------- So, tell me what you guys think?
May 1, 201411 yr Damn, just did a search and found the wiki link, which describes this orientation as Compound or 4th order band-pass enclosure. fml lol
May 29, 201411 yr I have one question. When figuring out the port do I use net our total after displacement?
June 5, 201411 yr I used the program and got the box figured out for two ethos 12's and I'm goin to do an external port but do I follow the port area for a ported box ( 80 sq. in.)? Or since all the sound comes from the port do they need a larger port? I want to give it an honest shot and get the best results. Thanks anyone
