well I got a new job doing 12V at a local shop, Nick you know it, Freemans at the lake, so I am going to use that to get my install finished. I had a pretty cool idea for a trunk. Here's a side view of what I was thinking. It was done using Paint so its kinda crap, but this is a general side cutout of the design. The woofer will be mounted inverted towards the rear of the trunk and angled slightly (40 degrees or less) and the two MOnitor MK I 2.70 will be mounted towards the front of the enclosure flush with it. A trim panel will cover it so all you see if the monitor sign. On the sides I'll do the usual walls to hold my distro blocks, crossover, and other amps. But what you think of the main part of the design.
shouldn't be too hard. The box I have is already fg'd into the spare tire well so now I only need to have it raised a little for that angle and then redo the part for the amp. But we'll see I know it would look nice if I can get it done.
GL!!
