Posted March 12, 201411 yr Can anyone point me in the direction of some? Trying to get some ideas for my Pontiac. Need to see what people have put in without tearing out the back seat. I have two 12W7's, two X12's and two Zv4's at my disposal. TIA
March 12, 201411 yr Author Gotta keep the back seat, I've tried to work around that but she's not budging!
March 13, 201411 yr Gotta keep the back seat, I've tried to work around that but she's not budging! Steve's was bad as f***
March 13, 201411 yr Smaller subs.I think I can find 4-4.5 cubes for one Zv4 That sounds a little bit better, thought you was planning to use 2 12s. That may be pushing it because IIRC, you have that huge as lump in the back inside the truck lol.
March 13, 201411 yr Author Your right about the hump. It kills all the space. And I'm going to be fighting for those 4 cubes either way. This "trunk" sucks.the good thing is with it being a hatch it should sound good.If i can do a zv4 with 2.5K on it I should be ok
March 13, 201411 yr Your right about the hump. It kills all the space. And I'm going to be fighting for those 4 cubes either way. This "trunk" sucks.the good thing is with it being a hatch it should sound good.If i can do a zv4 with 2.5K on it I should be ok um, enclosure sir. Please make sure you can fit that much space for amp, wire, box, and battery(s). Remember, uneven planes in your enclosure can produce ill results. I always aim for the box to be as even as possible. I know that hump has a big dip, so what I mean is, that dip should not be used as space for the enclosure.
