Posted March 20, 201412 yr Hello all, I'm in the process of designing a box for my 99 grand Marquis.One zv4 15 d1 running of a bc3500 @2 ohm for now, until I get a new alternator soon, then will do.5 ohm.The two options I have with the space available would be 3.5 cubes net with 60"port volume and 36.5"length. This would give me ~32 hertz...I think.Or 3.75 cubes net with 38.5" port length to give me ~30 hertz.So my question is, if I go with the bigger box with the lower tuning, will I lose allot of output in the top end? The sub will be firing up with the port firing back.I also cut out behind the arm rest and took the speakers out rear deck to let more air flow Through
March 20, 201412 yr Author Well this was what I came up with so far and I'm just learning. if I go bigger I need more port area, and length and it just gets too big. I want to have access to the amps which are mounted up on the hump
