Posted March 30, 201412 yr Sorry to ask because I know it's all over the forum but I cannot figure out what I need or where to get it. My AA has broken tinsel leads on one voice coil and I have no clue how to fix it. I would assume to fix it the right way, I'd need to pull the cone out, but after that I'm not sure what parts I'd need to repair it.
March 30, 201412 yr Sorry to ask because I know it's all over the forum but I cannot figure out what I need or where to get it. My AA has broken tinsel leads on one voice coil and I have no clue how to fix it. I would assume to fix it the right way, I'd need to pull the cone out, but after that I'm not sure what parts I'd need to repair it. Picture? I resoldered the lead on my evil back to the coil lead.
March 31, 201412 yr Author Sorry to ask because I know it's all over the forum but I cannot figure out what I need or where to get it. My AA has broken tinsel leads on one voice coil and I have no clue how to fix it. I would assume to fix it the right way, I'd need to pull the cone out, but after that I'm not sure what parts I'd need to repair it. Sorry to ask because I know it's all over the forum but I cannot figure out what I need or where to get it. My AA has broken tinsel leads on one voice coil and I have no clue how to fix it. I would assume to fix it the right way, I'd need to pull the cone out, but after that I'm not sure what parts I'd need to repair it. Picture? I resoldered the lead on my evil back to the coil lead. I just put it back together, but it's about 1/4 away from the coil inside the spider. I may be using my terminology wrong, but that's the best description I can give.
March 31, 201412 yr hopefully you understand what's caused the lead to tear? over excursion. check your setting, enclosure, and install. make sure the SSF is set correctly.
April 3, 201412 yr Author hopefully you understand what's caused the lead to tear? over excursion. check your setting, enclosure, and install. make sure the SSF is set correctly.Really? I wonder how I managed that. I haven't been pushing too much power, the box is actually 2cu ft tuned to 40hz, and all my setting are fine. How would that have happened?
