Posted April 5, 201412 yr If I was to get a s550.2 and two sets of pioneer components how could I wire them? If I was to wire them in parallel I would get a 1ohm load.
April 5, 201412 yr Author I have room in my doors for 2 in each and the ones hooked to my headunit aren't loud enough
April 5, 201412 yr Probably because they are running off of head unit power One good set on an amplifier will be good enough. Make sure you deaden those doors, great performance will come from a great install.
April 6, 201412 yr Sound deadening will bring any set to life, just look for a decent, reputable set and worry about HOW you install, not WHAT you install
