September 2, 201411 yr Author Now on to some updates. I started with the power wire that will be running towards the back. Two runs of of sky high 1/0 glad I was able to fit both runs along the side. The speaker wires from the door and dash wrapped up and will be routed. Then to find a place for the front stage amp. Was hard to come up with a place but however under the front seat was best place, didn't really want to put anything under the seat but I had limited space. So I made a base out of 1/2in mdf so it would be secured.A test fit to make sure it will be fine...Good to go so I will be placing it there. Time to remove all seats again... Now to start with the Audio control LC7i to help me integrate the factory amp to the other amps. Of coarse with a good diagram I got from TundraTalk.net to help me out with which wires are what I was able to knock this out. Now that I was able to get those wires done with the processor time to start cleaning up this mess of wires and start running them where they will go. Got my 12volt turn on relay in place to get the multiple accessories to turn one. Also got the Dakota digital in place while i was running all the wires. The voltage will be read from the sub amp.
September 19, 201411 yr Author Getting the box in for fitting. Also getting the holes drilled for T nuts. After i got the subs mounted in place it was time for the amp. After the power, grounds set, and a double check for everything it was time to finish the rest off... So I got everything playing and had a few issues. I had a tweeter not working which i found the problem which was where I soldered the wires together I guess I pulled the wire a bit to hard and it tore the wire, so I re solder and got it playing. The next big thing i have is with the aero ports are vibrating. I thought I had the in very secure when build the box but I guess not. I will have to try and fix this if I can't come to a decent idea to help prevent the rattle from the ports.
September 22, 201411 yr Author Got around to setting up the gains so here is a test vid of the Hertz. I will be needing to fixing the subs box due to some issues with the port rattling so I have the subs at zero gain as of now till I get around to fixing the problem. I know the issue with the ports but I will need to cut out the front baffle and replace it as I will be securing the aero ports a bit better.
November 11, 201411 yr any updates on this? As somebody with a crewmax getting ready to do some sub work, im very interested to see how the box fits with the seat in.
November 28, 201411 yr Author any updates on this? As somebody with a crewmax getting ready to do some sub work, im very interested to see how the box fits with the seat in.Yeah I have just been working on redoing the sub box since I messed up with the aero ports and didn't secure them properly. So I went and changed some specs to make it work as a slot port. The box ended up being slightly wider. Will be posting up some vids here shortly. I will also get a few pics of the box in with the seats up.
November 28, 201411 yr Author Just a few pics of it all installed. Just for the clearance for the passengers in the back
January 11, 201510 yr Author Just a bit of an update 12" bulletproof lift kit with icon coil overs sitting on 20x12.50 rockstar II rims with 38's toyo open country.
