Posted April 10, 201411 yr Anyone made the switch from the d3100s to these? Any big diff think my d310ps are taking a shit
April 10, 201411 yr I switched and for the price and performance theyre better IMOBeing able to pick them up locally on sale is great.
April 10, 201411 yr Author I'm about to run 4 15 ethos. I have a singer alt 320 and two 5500s think 3 would be cool?
April 10, 201411 yr I ran 4 3500's at .5 with 8 of them and a 320a alt and stayed in the mid 12's constantly.
April 10, 201411 yr I ran 4 3500's at .5 with 8 of them and a 320a alt and stayed in the mid 12's constantly. I run an 240amp alt, and 3 Plat's in the rear on a 5500 at half ohm, never drop below 12.8, hell, i don't never drop below 13.6 when driving full tilt
April 10, 201411 yr I'm about to run 4 15 ethos. I have a singer alt 320 and two 5500s think 3 would be cool? ETHOS!!!
April 10, 201411 yr I'm about to run 4 15 ethos. I have a singer alt 320 and two 5500s think 3 would be cool?Nope, you need one up front and atleast 4 of them in the rear.I ran a two 5500's with a 370amp alt and had 8 batteries(4 group 31's and 4 group 34's) to stay in good range.
April 10, 201411 yr Anyone made the switch from the d3100s to these? Any big diff think my d310ps are taking a shit Try to put them on the charger
April 11, 201411 yr At what voltage are you charging your batteries, also do you have a load tester? You can put a load on it and see if it drops to low voltage. Normally batteries just don't die, there is typically a reason if you keep your current setup you may just ruin another group of batteries.
April 11, 201411 yr Did everyone know that DieHard Platinum Batteries are made by Odyssey and Sold under Sears DieHard Platinum Logo! Odyssey is one of the best if not the best agm battery out there. Preferred and used by the military even. I use an Odyssey Group 65 PC1750. DieHards are just as good at a better price point : ) Edited April 11, 201411 yr by THX_Elite
April 11, 201411 yr Did everyone know that DieHard Platinum Batteries are made by Odyssey and Sold under Sears DieHard Platinum Logo! Odyssey is one of the best if not the best agm battery out there. Preferred and used by the military even. I use an Odyssey Group 65 PC1750. DieHards are just as good at a better price point : )They are similar to the odyssey 2150s although not as strong.
April 14, 201411 yr Author 13v start load tested drop to 11.5 with a carbon load tester @ 400 amps for 30 secs
April 14, 201411 yr Author Rose back up to 12.8 but when I charge my batts they rest at 13 and are fine out the car soon as its hooked up I wake up to 12.6
