So I should probably be more focused on finals, but priorities...
More progress, did 3 more layers outside, 4-6 (6 in the center where it has the largest span) layers in some places over the weekend.
So it ranges from 6-9 total layers.
Then cut out the holes (sorta, didnt go all the way to the flush ring yet.)
Got some resin and glass on the inside...
Trying to stick your hand in this thing with a paintbrush sucks.
looks like spiderman had a premature evacuation...lol
Nice work!
Nice work!
Does the crescendo s1500 come with a bass knob? And do you know if it is .5 ohm stable?
It does, but it feels cheap. I may try to use one that I already have.
And its not .5ohm stable. If you wana run .5ohm get a SAZ1200/1500 or IA 10.1
It does do over rated at 1ohm tho. An amp dyno test got a little over 1800 out of it on a certified 1ohm run
They are .5 stable pending you have the electrical to back it up.
Progress...
Got some rough spots sanded down inside, Finished cutting out the holes and did a test fit of subs and port.
So happy to be done glassing.
Also got the direct leads for the subs soldered and heat shrinked.
Probably start body work tomorrow.
looking good.
looking good
nice!
looking good.
Thanks guys, will hopefully have some updates thursday or friday. Finals exam week is killing me. Business law and accounting info systems are hell to study for, so tedious.
Nice build! Any updates on the enclosure?
Actually yeah, entire build is complete and I'm really happy with it. I just haven't updated it on here. Will update after classes today.
Good job ! Glass enclosure looks really cool!
