Lets see that playin!
  • Replies 186
  • Views 21.7k
  • Thanks guys, I really like the look I have going so far. I just ordered some black housing headlights and parking lights tonight so that should finish up the front as the tails are already painted/tin
  • Here are the other two videos I got that day.
  • Look what showed up today! 1500 watts of full range micro machines. For $300 shipped for the set I just couldn't pass them up after all the great reviews they have been getting. I should have plenty o
Fuck. Yeah.
Ok thats might have to be a copy cat
you're not the only one....I wish I had saw it before I mounted my HDD's.
Looks fierce Adam!
The still photos are on the blue setting, but I decided to take a video as well because the photos didn't seem to be doing any justice for how cool it looks. To me anyway.
Here is the video of the light show as well. Beware of flashing lights/colors!
Very good....now turn that damn sub up and wake up the neighborhood
I was playing it a little bit earlier in the day to make sure everything was hooked up and working correctly. Surprised no one called the cops. The xcon 15 had the cops cruising around in the past.
The sub has less than an hour of play time on it and is super damn stiff but I can get some good flex as it is.
  • 2 weeks later...
Look what showed up today. Another impulse score.
I did a 1 second burp for each frequency to see what response looked like. Pretty darn flat if you ask me. The exception would be the chunk from 44hz-52hz where I was actually trying to score. Driver door open, left display is in the kick, right display is at the headrest while holding rpm at 2k.147.56 at 50hz in the kick!!! I'll take it, considering this is my first time ever playing with a meter. I also took a video run on music at idle and did a 140 at 24hz, unfortunately my S3 seems to have corrupted the file.
Thanks Leedogg.
I've had some more time to play around and just listen to a variety of stuff. So far, the trident seems to excel at everything I have thrown at it. From pop and rock to hip hop and down to the DJSNT/Decaf/etc. Accurate and powerful. Nice tight kick drum when called upon and just gets silly with the lows. Have yet to try any electronic and dubstep now that I think about it.
Box is 5 cubic feet net tuned to 30hz with 99 inches of port. Running at 1 ohm on a BC3500. When not going hog wild and chasing raw output, it has a heavy low end and peaks around 24-25hz. It seems to roll off on the high end around 60hz or so and 23hz on the low end(SSF is set at that point). I am thinking this sub would benefit from a larger amp. I feel like I am overdriving the amp to get the sub to come into it's own and both amp and sub warm up pretty good.
I had a little time to get some music runs on video. This thing is playing very flat from the mid 50s down to the low 20s
  • 1 month later...
Looks like end of the line for this build. I am planning to down size vehicles so the tahoe is up for sale. I am sure I will continue my audio adventure with whatever I get next.
