Posted April 30, 201412 yr To make a long story short, the current HDC 12s that soundqubed is making have the hds300 basket. I bought one new and it did not come with the pictured basket on the website. Not all the way sure how I feel about it yet.
April 30, 201412 yr Author I would imagine the hds300's basket it's cheaper. The coils cooling is reduced. Those are two right off the bat.
May 5, 201412 yr The HDC series and HDS3 series will now use the same basket we use on the HDS3 series. The HDS3 basket costs us the same price as the HDC basket we were using. It has the same or better cooling capacity, excursion and strength as the HDC basket we were using. This allows us to stock one less basket. If we wanted to save money we would have used a stamped basket on the HDS3 series or a cheaper cast basket. We also wanted a more uniform look between the HDS3 and HDC series. We buy baskets in very large quantities so it does give us the benefit of higher volume price discounts from our supplier when we can use the same basket on both lines of subs. dj
May 5, 201412 yr Author Thank for your responce, is the HDC4 basket is also the same? What about the 18 inch version of both HDC3 and hdc4? What basket will be used for 18 inch woofers now?
