Looks great man!!! Welcome. I am curious of what you think of those subs as well!
  • Replies 263
  • Views 32.1k
  • Sencheezy
    Sencheezy
    That fur only takes away pressure... But I guess it'll look cool on SMD and youtube.
  • so this is just an idea at the moment but since im going to be rebuilding the system i was considering adding in a third 18. any thoughts on this??? and also any suggestions on an amp to power all thr
  • You mean IA, 32hz should be fine.
Screenshot_2014-05-16-14-57-56_zps25b99c
had to wrap the front baffle before it goes in. got the material for about 5 dollars a yard. thinking i might switch to purple fur the match the color of the car though
Looks good
Nice work!!
Looks good
thanks man
Nice work!!
thanks i appreciate it!
Screenshot_2014-05-17-15-32-31_zps03624e
Screenshot_2014-05-17-15-32-38_zps62ce5d
painted the inside of the port
Screenshot_2014-05-17-15-32-27_zps15bba1
port and baffle going together!
Screenshot_2014-05-17-15-32-16_zps5475f3
sides getting glued down to the bottom
TUNED IN!  I also have a DR that I am going to run in my Burb...looking forward to see how you like the Judges.
I like what I see :)
Nice equipments in a European sized car ! I love it !
Tuned in for sure !!!
thank you!
thank you!!
Screenshot_2014-05-17-15-32-13_zps29cb9e
face and port piece getting ready to go in!
getting so close to hearing them play
Screenshot_2014-05-17-15-32-07_zpsd2d602
probably going to rip off all of the vinyl and replace it with a fake fur or something. It will work for now but im not a big fan of it shrug.gif
i guess its time to go out and get some fiberglass since i forgot it up till now -_-
Screenshot_2014-05-17-15-32-09_zpsed8422
it comes a little past the the back door but i don't mind. i didnt want to make the box any smaller... and who needs back seats anyways
Screenshot_2014-05-18-16-04-18_zps070be8
tried out this primer before painting and so far was the best primer iv used on a box. only took one can and sands down very smooth. would def recomend
Screenshot_2014-05-18-16-04-30_zpsbddd59
got some fiberglass laid down. still lots to do
Screenshot_2014-05-18-16-04-07_zpsffd9fb
test fitting the back and the top.  sorry for the half blury pictures. something isnt working right with my phones camera
Screenshot_2014-05-18-16-03-24_zpsbf32c9
well even though my car was already sitting on stiffer lowering springs its sagging hard in the back. its kind of hard to tell in the pictures.
going to be modifying the suspension again to even it out but not sure how yet. either installing coilovers or going all out and running air suspension. any suggestions???????????????????????????????????????????????
alright time to get the back and top bolted down and get these subs in there!!!
Well get it done then :)
Looks good so far!
Screenshot_2014-05-19-13-43-20_zps318f2c
first box iv ever built that i could fit inside. Im 6'4" too!
got the top of the box glued and screwed and used the extra resin i had to coat the sides. just waiting on it to dry so i can vacuum it all out and mount the subs in
Screenshot_2014-05-19-13-42-40_zps81356a
Screenshot_2014-05-19-13-42-57_zpsedbac2
