Nice collection of amps!
Thanks!  Though, I really want to replace the front stage amps (everything but the cadence) with a pair of ppi900.4s to save space.
  • Replies 139
  • Views 30.1k
  • Hey guys, I'm back with an update. Weather hasn't cooperator with me but what do you expect this time of year.     I attached the tweeter pods to the mid range pods with some epoxy. Notice I
  • updated pics. I'd like to get the left midrange a bit more to the left as it sounds very much from in front of me rather than the side.
  • So the issue with the midbass is pretty much solved. see this thread:   I'm planning to start the A pillar pods this weekend. But first I made a small upgrade to the amps. Polk must be
Deadened the roof today. Someday i would like to order some 3m thinsulate acoustic from Don.
used 10 tiles on the roof. 6-8 tiles would have been plenty but I have like 30 tiles left to use in the front doors.
Nice! Are you talking about the ccf?
No need for CCF on the roof, Thinsulate is pretty much the only thing you can use that actually absorbs sound for a car installation. Foam would have to be much thicker.
http://www.sounddeadenershowdown.com/how-to/roof
Ahhh, didn't know he was carrying that now
i think don is the only one who does.
  • 2 weeks later...
updates.
false wall and floor are done for the most part. Going to try some carpet dye to lighten up the carpet later. I wanted to make the sub vented properly into the trunk so i created the oval hole. Came together well enough I think.
I used a chamfer bit on the router around the edge of the hole and used a rabbiting bit recess around all the edges.
the grill cloth is just stapled on.
These are the mounts for the false wall. (red dots)
7e877a9b-5eed-4ec8-a6f9-f5c867b783c9_zps
Finally ready to move on to the front stage and tablet install.
Edited by lithium
why the grill cloth looks like totally different colors in the pictures must be my camera. actually it looks almost purple in person. I might order some better quality cloth later.
Looks very clean
wow looks good!
thanks guys.
deadening pics:
I had tons of cdl tiles remaining so i went a little overboard. Then again, the sls 8's are some pretty serious drivers.
As you can see, i focused on the flat portions of the panel. The outer door skin got ~50% coverage with tiles.
I popped the grill off the factory trim panel. The factory 5.25" speaker will be replaced by peerless sls 8's.
I removed the factory speaker and lowered the window down to measure mounting depth. The sls8's need 4.4" mounting depth, cutting the trim panel will be necessary.
Here's an idea of how much of the trim panel i will need to cut.
  • 3 weeks later...
starting the nexus 7 install.
fits well with out modification.
my first idea for mounting the tablet is using these straps and buckles.
i was worried they might not hold the tablet firmly in place but they seem to do the trick. I realized later that the knots aren't necessary, lol
I need to do some wiring and then program the steering wheel controls to finish the tablet install.
moving on to the midbass install. I made baffles out of 3/4" mdf. To water proof I started with 2 coats of resin. If you've painted mdf before you know the edges are very porous so after 2 coats i decided to used a rubberized spray sealant. I think it was the rustoleum brand.
The baffles are secured with 3 bolts (perhaps i should have used 4 or more bolts?). I also used butyl rope to seal the baffle to the door. And applied duct seal for the hell of it.
after some rain i noticed water collecting on the baffle noted by the red circle below.
i'm trying to come up with an idea on how to direct water away from the speaker.
My first idea was to hack up some of these.
http://www.crutchfield.com/p_237XT68/XTC-6-x8-Speaker-Baffles.html?tp=2809
and finally some pics with the door panels on. My solution for covering the midbass and everything will be one of the last things I work on. I need to make sure the doors can handle the midbass. I may go with enclosure or something if thats the case.
top down view. I could have move things down and to the right a bit more.
other side is a pretty close match, thank jebus
$11, worth a try i think. I'll have to cut out the bottom so the speaker remains IB of course.  I'll wait a day or two to see if you guys got a better idea.
http://www.crutchfield.com/p_237XT80/XTC-8-Speaker-Baffles-6-depth.html
Im actually surprised my sls 8s have lasted this long.
Edited by lithium
I was going to suggest using thin guards like plexi but the cups Sen like an easier install with some modification. I might do the same for my door. I found water in the sill today after the storm
ya just spending $11 will save me a lot of time and trouble fabricating something
I am anxious to see how you are going to finish your doors.
  • 2 weeks later...
anyone have an idea on how to dampen the metal rod things that go from the handle to the door latch?
Edited by lithium
 right haha. shouldn't post late at night.
got plenty of left over ccf so i'll give that a try.
  • 3 weeks later...
updates
started the kicks
tried a new technique using full sheets of mat.
Trimmed back the excess. Obviously these will be trimmed back much further. Burned through all my dremel disks... should have used a jig saw.
Testing out some off axis aiming. Driver side tweeter will have to clear the E-brake and aviod firing straight into my left leg.
I tried using plumber's tape to support the speaker rings and allow easy aiming but they cant handle the weight of the speakers.
I realized the passenger side tweeter is lower than the driver side. I'll be trying a few different configurations.
