Posted May 18, 201412 yr Equipment: 4 18" sundown zv4taramps hd8khifonics zues 2000.4digital design comp front stage digital design coaxial rear fillKnuconceptz rcas and speaker wire350amp singer alt with overdrive pulley4 xp3000s rear d3400 front1 run 4/0 power 1 run 4/0 ground multiple grounds in rear4th order is 2.20 sealed per 6.375 ported per sub ported will be tuned to 52hz all behind cpillar. Full use of backseats. Pics to follow
May 20, 201412 yr Bad ass build! BTW- Auburn shorts in Michigan? War Eagle! Edited May 20, 201412 yr by Leedogg
