How much port area would you reccomend for a 12" zcon in 3 cubes @ 30hz? Will be powered by a saz2500d.
Spend two minutes modeling it under power in WinISD and you will know your trade-offs.
Every time I model something in winisd I feel like changing the power shows no difference. I could be doing something wrong maybe?
Well maybe I meant when changing the port size in winisd nothing changes on the graph, I see changing the power just makes it louder(more dbs) on the graph.
Edited by blowthemup
No luck with this, i installed a newer version of winisd and now it wont accept the zcon parameters.
You have to hit tab. Put in the first parameter, hit tab, put in second parameter, then tab twice and it should fill some things in automatically.
