  • Replies 86
  • Views 13k
  • Hey, look. DSS Ethos got an award at Slamology.
  • Just finished my last set of rings last week and forgot to mention I ran in to some rules in my organization that stipulates that I cannot run legally with unfinished doors. Well, I'd be working on th
  • jonbearsmt
    jonbearsmt
    sweet subs !!!    why that amp ?
layout looks great in person !
Looks good man
Hope to finish covering both sides. Instead of covering the floor I will have another removal false floor that sits right in front of the box and is removable so I can slide the box back and forth for daily/competition use. Have yet to get my Psychoports because of cost, but I will make what I have work for the time being.
Honestly, the hardest part is knowing what amps I'll be running between now and finals.
I have these spools that are made of hard plastic...we use them at work they hold the zippers down the 8" x 15" long i would post a pic if you would like to see them
By all means let's see them. I'm currently running the 2 ports at 12" a piece simply for ease and cost. It was cheaper than 4 smaller at least I thought.
ca52e3081124e5c3f82579ac3b4ec62e_zpsfde4e37f86fe18448edadf80851672a9a3b1_zpse2984be2fdcd6c9c1b0dcfff09e1ee3e2565_zps3410
I have four of them I can get more when ever we run them some time next week there free no need to make money just pay for shipping if you want them.
I think after doing my calculations I will pass on this so someone else can benefit from that deal. The 12's i'm using cover much more area over the 2 vs having to use 4 of the 8's. I'd actually have to end up using 5 of the 8's and they would still need to be lengthen'd so I don't tune too high.
I thought about this afterwards and should have said something then. I really do appreciate you taking the time and those look like they could make some damn good ports. Thanks man!
Who ever can get them
wrapped in glass mat and resin those would be nice and strong.  And the smooth inside would gain some debeezzzz, lol
Nice of you to offer to someone.
  • 3 weeks later...
Well, long day, but I did get the box looking a bit better. Not done yet as I got some measuring and cutting left on the sides and floor. It will be pretty when done.
Is this box a window line box if so how tall is it trying to build me one for 3 18s I don't want to wall it off just want to know the height of yours. I'm going to be changing my class from local to national and running in two classes basic 4 and Kaos 2 (midwestspl)
It's build to stay under the rear seat line. I do believe that the box itself is over that line when the subs are loaded. I will double check when I get home from work.
