Posted June 10, 201412 yr so this kid on SMD claims that i should be ok with an 80 amp stockalternator running off an audio pipe 2000 together with a rockford 250.4 as it is i have major volt drop, have a yellow top under the hood andan xs power xp950 I'm looking forward into buying a singer alt 180 amps but trying to see if it'll be good even after i purchase a largeramp which I'm thinking about the soundqubed q1 3500 let me know what you guys think, should i stick to the 180 amps and stillbe good in the future? (still gonna purchase a second xp950 in the near future)
June 10, 201412 yr Im not a kid and i suggested the 180 singer EDIT- or you can go buy the 800$ dc alts everyone else suggested. Remember YOU said the singer alt, not me. If your not wired low, and your seeing that big of a drop, then something else is up Nice to meet you again. Edited June 10, 201412 yr by Kylar96
June 10, 201412 yr so this kid on SMD claims that i should be ok with an 80 amp stockalternator running off an audio pipe 2000 together with a rockford 250.4 as it is i have major volt drop, have a yellow top under the hood andan xs power xp950 I'm looking forward into buying a singer alt 180 amps but trying to see if it'll be good even after i purchase a largeramp which I'm thinking about the soundqubed q1 3500 let me know what you guys think, should i stick to the 180 amps and stillbe good in the future? (still gonna purchase a second xp950 in the near future)Even with a 180A alt you're going to need more battery than 70AH, in my experience 1 group 31 per 2500w, so you're going to need at least 2.
June 10, 201412 yr also.. i tried to HELP you KyLar96, on 10 Jun 2014 - 3:18 PM, said:for what your running there, you dont even need a HO alt.... just me. Did you read his first postHe said he's looking to upgrade k.. then the 180 will be fine...... Did you read his 11 other posts that he only has bank (edit, i mean MONEY here) for the alt he mentioned? Do you see him running a audio pipe amp? Just me, BUT, i dont think this member needs a 700$ alt. Appreciate the heads up though, bro.....
June 10, 201412 yr Author also.. i tried to HELP you KyLar96, on 10 Jun 2014 - 3:18 PM, said:for what your running there, you dont even need a HO alt.... just me. Did you read his first postHe said he's looking to upgrade k.. then the 180 will be fine...... Did you read his 11 other posts that he only has bank (edit, i mean MONEY here) for the alt he mentioned? Do you see him running a audio pipe amp? Just me, BUT, i dont think this member needs a 700$ alt. Appreciate the heads up though, bro.....yet again, you didn't have to be a b*tch about it, its advice man, you take it to thenext level. You didn't even bother reading through the post until the second page, thereare different ways to communicate rather than just outputting thoughts and opinions.. yet, thanks
June 10, 201412 yr Author so this kid on SMD claims that i should be ok with an 80 amp stockalternator running off an audio pipe 2000 together with a rockford 250.4 as it is i have major volt drop, have a yellow top under the hood andan xs power xp950 I'm looking forward into buying a singer alt 180 amps but trying to see if it'll be good even after i purchase a largeramp which I'm thinking about the soundqubed q1 3500 let me know what you guys think, should i stick to the 180 amps and stillbe good in the future? (still gonna purchase a second xp950 in the near future)Even with a 180A alt you're going to need more battery than 70AH, in my experience 1 group 31 per 2500w, so you're going to need at least 2. so you think ill be ok? just add a few more batteries? Edited June 10, 201412 yr by Basshead956
June 10, 201412 yr Author just wanted some advice, would i be ok with an 180 amp? or should i save up a few hundred more, simple!
June 10, 201412 yr also.. i tried to HELP you KyLar96, on 10 Jun 2014 - 3:18 PM, said:for what your running there, you dont even need a HO alt.... just me. Did you read his first postHe said he's looking to upgrade k.. then the 180 will be fine...... Did you read his 11 other posts that he only has bank (edit, i mean MONEY here) for the alt he mentioned? Do you see him running a audio pipe amp? Just me, BUT, i dont think this member needs a 700$ alt. Appreciate the heads up though, bro.....yet again, you didn't have to be a b*tch about it, its advice man, you take it to thenext level. You didn't even bother reading through the post until the second page, thereare different ways to communicate rather than just outputting thoughts and opinions.. yet, thanks Good luck. My first post was you dont need a 800$ alt.But ok And,......Kid?Also, thoughts and opins are not what i said. Good luck.. enjoy your ride. I wish you luck.
June 10, 201412 yr so this kid on SMD claims that i should be ok with an 80 amp stockalternator running off an audio pipe 2000 together with a rockford 250.4 as it is i have major volt drop, have a yellow top under the hood andan xs power xp950 I'm looking forward into buying a singer alt 180 amps but trying to see if it'll be good even after i purchase a largeramp which I'm thinking about the soundqubed q1 3500 let me know what you guys think, should i stick to the 180 amps and stillbe good in the future? (still gonna purchase a second xp950 in the near future)Even with a 180A alt you're going to need more battery than 70AH, in my experience 1 group 31 per 2500w, so you're going to need at least 2. and if you read the post again, I'm getting another battery (soon approximately next week but instead of helping you just rather put people down! come on homie When did i put anyone down?
June 10, 201412 yr And, you mention you getting more AH's over there, but here.. you didnt.. thats why a member said more... Man........ no way, no how im the turd here.. Go see if the amps you have can even pull 200amp...... done.
June 10, 201412 yr Author so this kid on SMD claims that i should be ok with an 80 amp stockalternator running off an audio pipe 2000 together with a rockford 250.4 as it is i have major volt drop, have a yellow top under the hood andan xs power xp950 I'm looking forward into buying a singer alt 180 amps but trying to see if it'll be good even after i purchase a largeramp which I'm thinking about the soundqubed q1 3500 let me know what you guys think, should i stick to the 180 amps and stillbe good in the future? (still gonna purchase a second xp950 in the near future)Even with a 180A alt you're going to need more battery than 70AH, in my experience 1 group 31 per 2500w, so you're going to need at least 2. and if you read the post again, I'm getting another battery (soon approximately next week but instead of helping you just rather put people down! come on homie When did i put anyone down? leave it at that man, thanks anyways
June 10, 201412 yr Author And, you mention you getting more AH's over there, but here.. you didnt.. thats why a member said more... Man........ no way, no how im the turd here.. Go see if the amps you have can even pull 200amp...... done.lmao thought i had, sorry about that one but yea 2 xp950 from original post** (running all sky high 1/0planning to get a second xs xp950 (have one in rear) and have a yellow top infront(will also upgrade Edited June 10, 201412 yr by Basshead956
June 11, 201412 yr Do Not EVER bring shit from a different forum, especially THAT shit hole over here.
June 11, 201412 yr Figures that 7th grade pre-pubescent activity stems from there. Just to clear things up. There is basically ZERO good information on SMD so take everything there as a nuthugger dipshit comment and move on.
June 11, 201412 yr It appears to me as if your questions have been answered. You need more battery and alt.
June 11, 201412 yr Buy the biggest alt you can afford. Thats about the best advice for ANYONE looking to buy one.
June 15, 201411 yr Buy the biggest alt you can afford. Thats about the best advice for ANYONE looking to buy one. Fully agree. electrical is the backbone of your build, without it, it will fail.Go for the biggest alternator you can afford/can get for your car, and then slowly shove as many g31s in your car as you can until your voltage is where you want.
June 15, 201411 yr He runs 2 "small" amplifiers. And he already has two batteries.I don't know if he did the big3, but I can't understand why he has major voltage drops. There must be a problem somewhere.I'm not an expert at all. Of course running the biggest alternator you can will always be a good thing. Especially if you run a 3500 watts amplifier. You will need more or bigger batteries too. Good luck.
June 15, 201411 yr Theres something wrong with your build... you shouldnt have major voltage drop with an 80 amp alt w/ 2 batts. your probably pulling like 200 amps with both amplifiers lol. What kind of wire are you using?
