Posted August 4, 201411 yr i want to buy 2 fi bl 12s ported box dunno if it will fit in my car its a 2012 ford fusion
August 4, 201411 yr I don't know if it'll fit in your car either, but it would fit in my car. I have a volvo v40. If you bought a v40 then they would fit. You should probably buy a v40 to be on the safe side.
August 4, 201411 yr I used to have a 2012 fusion. I'll have to look at my previous designs to see the max dims. However, I did have my subs/port front firing so idk if that's something you wanna do.
August 4, 201411 yr Author i think ill stick with 1 15" fi BL trunk looks small.I'll just get it fully loaded but im worried about overpowering it.I have a hifonics brz2100 running 1 ohm load
August 4, 201411 yr Author i have 1 mtx 9500 12" with recommend specs but im not satisfied with it will fi bl 15" sound any better
