Posted September 11, 201411 yr I have a older dual slug Q and I want to run two Q's now. Would I run into any problems running a newer Q with athe older one in a ported enclosure?
September 15, 201410 yr Email fi directly for a definite answer, but I believe you can run the older Qs with the newer ones. Someone a while back had the same question, maybe you can dig it up with the search.
September 15, 201410 yr they came back with a no, has to do with different motors and what not the reason i was asking cause i have an 07 q15 looking for a match
September 15, 201410 yr but I believe you can run the older Qs with the newer onesNo. Okay, well it depends on what you mean by can. You "can" run a Kicker L7 with an Fi Q I suppose, just not a good idea. Anything that creates a difference in t/s parameters is a no no for drivers playing the same frequencies. Even worse if it shares airspace.
September 15, 201410 yr Author I figured that would be the case. I just can't seem to find the specs for the older Q. I love my Q and came across a good deal for second but its a newer one. Even the power handling is different.
September 15, 201410 yr I would sell your older and buy the newer single slug motors as they are not hard to find as of right now.
September 16, 201410 yr but I believe you can run the older Qs with the newer onesNo. Okay, well it depends on what you mean by can. You "can" run a Kicker L7 with an Fi Q I suppose, just not a good idea. Anything that creates a difference in t/s parameters is a no no for drivers playing the same frequencies. Even worse if it shares airspace. I already new that, but sometimes new versions of the same driver are close enough that they can be used together.anyways glad you got it figured out OP.
September 22, 201410 yr Author I ended up buying the newer one. The guy sold it to me for 175 and I could pass it up. Now to find a matching newer one or wait to see if it goes on sale for black Friday.
